Question about Sharp VL-Z100U Camcorder
Blank lcd screen
When i open the lcd screen can only see white background with a grey inch line down the centre can record and view ok through the viewfinder with no problems
  • 8 Answers
SOURCE: blank display
Hi all. Recently got same problem as others with remove lens cap when in camera mode or black screen. It is a known problem with the ccd. JVC have admitted this (at least over here in the England they have). They are doing free repairs until October 2007 even though I'm out of guarantee/warranty. Here's the URL for UK, hope you get lucky. Regards Tony
Posted on Oct 15, 2006
  • 19 Answers
SOURCE: Panasonic NV-GS30
please check Video head tip, if it is OK. Clean Video head with Head cleaning cassette. If Head tip is damaged head to be replace. thanking you & best of luck.
Posted on Nov 20, 2006
  • 326 Answers
SOURCE: no visible picture in camera mode
Hello Kenza, replacement of CCD that belongs to Lens device. Please contact your nearest Samsung Service. Best regards, Arpad
Posted on Dec 24, 2006
  • 76 Answers
SOURCE: LCD is blank
Yes but needs to go to service .The strip connector between the lcd and main pcb board is faulty and needs to be replaced.
Posted on May 22, 2007
  • 48 Answers
SOURCE: No Display on LCD
If you have used any kinda abresive cleaning product on your LCD screen is is most likely finished and needs to be replaced or it is faulty from the beggining. You must go for and exchange or a repair replacement of the LCD..
Posted on Feb 18, 2008
  • 10594 Answers
Following Sony web link has news to help you in this problem.
Posted on Jun 12, 2008
0 characters
1 Points
I have sound and can view previously recorded videos on my camcorder. However, on Christmas morning my camera doesn't record or view images. It just records a black screen with white lines. The li
The recording head is probably the source of the problem and will need to be replaced, other than putting a dry cleaning tape or better still a new blank tape, allow it to play right through, it may work.
Mar 10, 2012 | Sony Handycam DCR-DVD105 DVD Camcorder
Horizontal grey lines on a dark grey screen in recording mode
CCD Failure !!
u can try Sony for free CCD replacement as it is a known issue in thousands of cameras see the link here, it starts with these horiz lines and verrtical noise type thing and suddenly it also turns black or blank screen after sometime , u are covered in this advisory list 100% i am sure see the links below and pls rate me FIXYA for help
see this comment on cnet forum
DCR-TRV33 Free Repair by koertd - 3/9/08 3:45 PM In reply to: Sony DCR-TVR22 – tape stuck by willibo Thanks to all. Ready to trash my DCR-TVR33, but found the cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif800-222-1669cb_transparent_r.gif number. While holding, I found online support at:
(I guess several trips to Hawaii and Fuji didn't help the humidity/temperature issues!)
The friendly Sony representative had me reset the camera and then offered to have the problem fixed for free, including shipping.
see this forum here
What do u think Mr. Welcomejee have i diagnosed it correctly or not ?
Apr 11, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
DCR-HC19E Camcorder LCD Screen not Working
DCR-HC19E has cracked/ broken flexible cable, connecting LCD and main camera board.
Jun 30, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Blank LCD screen
no screen display
Dec 01, 2007 | Samsung Video Cameras
Pink or grey horizontal lines on video download or viewing
I have the same issue and have for over a year (haven't had the time to send it to Canon for a few weeks to analyze, but have cleaned it numerous times). But I can tell you that the problem is internittent and the recordings are fine. Eventually, don't know the remedy, but it will suddenly stop doing that and I can download fine, and watch on camera fine. When it does happen, I just keep recording. It never shows up permanently. I re-tyr downloading or viewing and about the 3rd or 3th time (let it sit for a few hours between) it is normal!
Oct 09, 2007 | Canon ZR90 Mini DV Digital Camcorder
LCD Screen Blank
hi, this usually happens with the ribon cable which is giving power and signal to LCD is becoming loose or damaged due to folding..since the LCD wiring replacemet is a skill needed task i recommend you to give it to the nearest service centre so that your cam will be ready for future shots all the best my friend sreejith
Jun 26, 2007 | JVC GR-DVL9000 DV Digital Camcorder
No LCD Display when opened at 90 degree
Dear sir, If the Picture in View finder is connect, then problem in LCD ribbon cable. LCD Ribbon cable may damage. Replace LCD ribbon cable. thank you, replie if any problem
Jan 17, 2007 | Panasonic NV-GS35 Mini DV Digital...
The LCd connecting Flexible strip might be faulty. If you can view the picture in dark way,then the back light can be the faluty part. If they are all OK, then replace the LCD. The connecting strip is failing fast as per our experience and this costs US$ 21.00 and it is available with us.
Dec 28, 2006 | Sony Handycam DCR-HC42E Mini DV Digital...
Panasonic NV-GS30
Nov 18, 2006 | Panasonic NV-GS30 Mini DV Digital...
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Sharp VL-Z100U Camcorder Logo
21 people viewed this question
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
