Question about Car Audio & Video
MFD2 CD read error - Car Audio & Video
I receive error when CD is put in computer:
It is very common for dust, dirt, or other material on a CD or CD-ROM drive to cause the CD to be improperly read or generate errors because data cannot be read from the CD. If you are running Windows it or its related drivers may be corrupt and is causing the CD-ROM drive to not be properly read.
For additional information click the following link: https://www.fixtoolbox.com/cdfreefix.html
(CD Fix Toolbox Free)
Jan 19, 2016 | Audio Players & Recorders
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Just bought a 2002 exlorer. can't load cd's into cd player. reads cd error
I have found that any "burned" discs will not be read on older cd/radio combinations. The newer sets will tell you on the box what formats can be read...I also found this to be true on dvd players
Jul 29, 2012 | 2002 Ford Explorer
I have 2006 chevy impala What does it means I try to put my cd in to play its say error
It means that your CD player is not reading the CD , try a different CD and preferably original CD and see if it reads it then. If the CD player works ok then, you had bad CD and if it should read error again then the CD player it self is defective.
Jan 22, 2011 | 2006 Chevrolet Impala
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Cd roms wont read it says i/o device error
Your error is usually indicates that the drive can't read the CD. I ask everyone these two: check to make sure the CD is right-side up (label facing up or to the right on a vertical oriented drive) and did you insert a DVD into a CD drive? Can you use Windows Explorer and right-click on the CD drive letter and select eject and it works? If not, a driver could be missing. Lastly, if you inserted a blank CD (that can be written to) into a CD drive that can only read CD's, you'll get that error.
Dec 26, 2008 | Computers & Internet
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
