Question about Food Mixers
Mixer will not run except for pulsing on setting 12
Model smx1
Speeds do not work in graduations in Sunbeam Model 2371 12 speed mixer
Problem with speed control device. Check switch for continuity with various speed settings.
Dec 24, 2016 | Sunbeam Food Mixers
Sunbeam mixmaster 12
There's a governor assembly inside that is bot working any more.
Sep 15, 2016 | Sunbeam 1957 Mixmaster Model 12 Kitchen...
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
My KitchenAid Mixer switches on, but doesn't pulse.
Explain please , the mixer does not pulse like a food processor does it just spins.
Aug 08, 2013 | KitchenAid KP2671 Professional 6 Series...
My stand mixer's motor runs but the blades don't turn to mix the food
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
The Worm Gear (12) teeth was stripped and needs to be replaced.
The whole Worm Gear Assembly can be purchased on eBay for under
$15.00
Aug 04, 2011 | KitchenAid K45SS Classic Stand Mixer
Top part of mixer is bouncing when in use.
Hi and welcome to FixYa, I am Kelly.
The Head Lock is most likely worn. The 4.2 mb Service m\Manual is located here:
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
You may have a worn hinge pin: Figure 7 page 7 of the pdf file.
The spring for the head lock can be also broken. Item 20 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136226&diagram_id=28251571#d28251571
See page 22, figure 72 in section 5 of the service manual for pedestal hinge repairs. Most likely the set screw for the head lock has come loose.
Your parts can be found here: (with some exceptions like item 20 above)
http://www.searspartsdirect.com/partsdirect/part-model/kitchenaid-parts/mixer-parts/Model-KSM90/0593/0212320/P0408117/00004
This information should get you going if your able to read the manual and follow the sometimes vague instructions.
Thanks for choosing FixYa,
Kelly
Jan 02, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
My mixer runs great except it doesn't seem to get quite as fast as it used to.... almost like 'top speed' doesn't kick in...so it doesn't whip like before...any ideas? thx!
BREZZZLINThe inspection and troubleshooting of your mixer’s insides is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KPM2671 and select the appropriate file under Parts List and then check to see it this matches your mixer model. You’ll need Adobe Reader to be view/print the file.
Based on how you’ve described your mixer symptoms, I suspect there’s a problem in your controller assembly; particularly at the high (#10) setting. I'd start there and inspect the controller assembly first. It's possible a connection has become loose and only needs to be reseated. If your visual inspection yields nothing, then its probably the somewhere in side the controller assembly. Unfortunately the whole controller assembly is on a little PC board filled with resistors, capacitors and diodes, and was not meant to be 'home fixed'. My 'expertise' ends at being able to recognize a resistor from a capacitor, but I don't get much deeper than that. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not.
Good luck, I hope this helps! Howard – Burke, VA
If this solution has helped you, please rate it, thanks! hslincoln
Nov 27, 2009 | KitchenAid KP2671 Professional 6 Series...
Turntable does not turn. Motor runs. Beaters work.
I have the same one, and the turn table has never turned on it's own. from looking at the bottom of the stand, i think the mixers are supposed to turn the bowl, so i just give it a little turn, and the mixers kinda take care of the rest. BTW, i got 2 sets of beaters with mine and i dont know what the second set is for, do you? contact me at rawemo@hotmail.com
Feb 18, 2009 | Sunbeam Food Mixers
Doesn't stay on
They are junk! If you are hands on savvy look for my other posts on disassembly. Then, make sure grease is not seaping into the motor area and then clean every contact using contact cleaner. Filing the "points" is also worth a try. Lately, you can't buy one of these that isn't junk. Have you seen all the posts??
Jan 05, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
22 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
