Question about Roadstar LCD7310 7 in. Portable TV
How to tune to digital channels - Roadstar LCD7310 7 in. Portable TV
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
I have just been given a Panasonic TC-29V26A colour TV in perfect working order. I connected my Digital box to it and had no problem, I just can't get any non digital channels to tune in...even following...
U only get digital channels,that work propperly notthing wrong.Get a digital antena might all the other digital not getting.Non digital will not tune in any more.
Feb 10, 2010 | Televison & Video
I have lost channels 5,itv 3,and itv 4,and do not know how to retune my tv, all other channels appear to be alright slightly confused when i press the menu button and not know which links to follow?
All Freeview channels need re-tuned after 30th September.
To re-tune your Sony TV...
1.Press Menu button then go to settings...
2.Scroll down the menu icons until you get to 'Digital Set-up'
3.Press enter/centre key next to direction arrows
4. Select spanner icon and digital audio tuning.
5. You will then be asked if you want to start digital audio tuning.
6. Press enter/centre button....and thats it!.... TV will automatically re-tune.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Mar 22, 2009 | Televison & Video
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Digital TV Tuning problem
I would try letting the set autoprogram again.
Mar 07, 2008 | Televison & Video
Roadstar LCD7310 7 in. Portable TV Logo
400 people viewed this question
Top Roadstar Televison & Video Experts
Are you a Roadstar Televison and Video Expert? Answer questions, earn points and help others
