Sony kdl26u3000 how to connect sky - Televison & Video
Sky decoder connection diagram
Which sky box do you have, This is the diagram for a Sky+HD Box:
http://prod-help-sky-com.s3.amazonaws.com/uploads/TV_SetUpBox_ConnectCables_L.jpg
Oct 22, 2013 | Sony Televison & Video
I HAVE AN OLD THOMSON SKY BOX(NON HD) CONNECTED TO A SONY BRAVIA 32BX320. THERE IS A POOR RECEPTION ON SKY CHANNELS PARTICULARLY NOTICEABLE ON SKY SPORTS FOOTBALL WHERE IMAGES ARE "DRAGGING", "DELAYED
First step...clean out the "old" guy with clean, dry, compressed air to get dust off the capacitors and resistors. The frequencies that the "box" selects are regulated by those components. If this doesn't work you should realize that the electrical values of those components change as they age...and like grandma, can't do the tricks they used to.
Jan 12, 2013 | Televison & Video
I have a sony mp3 walkman i can connect the usb to the side of my tv and it will play my music files etc but when i connect it next to the sky viewing card on my sky hd box it says no connected devices...
Sky put the USB ports on the boxes in case they wanted to use them in future. They are there but not active.
Bit like the eSATA socket on the back, it isn't used yet but they had ideas to use it!
I guess if they had to replace boxes all over the country to put a USB in would have been a bit of an issue for them, so best they fitted one from the start...
Nov 16, 2011 | Sony Walkman NWZ-B142 MP3 Player
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
SONY Bravia
Try changing the cable to another connector. If picture is still poor, try changing the cable for a new one. Also verify that the sky unit is giving a good picture by connecting it to another TV and see if picture is clear.
You could also verify the connections on the TV by inputting video from another source such as VCR or video camera.
Dec 30, 2007 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
