Question about Invacare Health & Beauty
GTRAC-PMA90A with MPJ+ joystick and Mk6i electronics. yellow CTRL Inhibitied. can't get to work
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: What would cause the display of the message "MPJ
This display message can be caused by some of the following:
Joystick out of neutral at start-up.
Bad or broken joystick gimble.
Bad or uncalibrated joystick gimble.
Bad wiring harness or connector from joystick
Internal joystick electronic component problem.
Bad communication chip in joystick.
Incorrect programming of the joystick
The most direct test is to run the joystick gimble in circles and forward, back, left, right, feeling for bad or dead spots and uneven action. Look at the position in neutral: left,right, forward ,back should be in alignment. A bad gimble is inexpensive and straightforward to repair.
Inspect the wiring for cuts, pinches and bad pins on the mating connectors.
With a hand held programmer (HHP) plugged into the main harness or charging port you can read the fault log. That way you can make a definitive diagnosis. You can also calibrate the joystick with a HHP and adjust the programming parameters.
If the chair powers up but the batteries are low you can get unusual electronic problems so test the voltage with a digital voltmeter. Voltage should be between 24 and 26 volts. It is possible but less likely you have a bad controller. Again, the HHP will read the register of all faults to help you determine the cause of your problems.
Check the obvious first and then swap out the joystick with a known good working one to determine definitively that the joystick is your problem. Hope this helps.
Posted on Dec 11, 2010
What does 7 yellow flashing wrenches mean?
With most wheelchair electronics a 7 flash means the joystick is bad. A 7 flash means "joystick is out of neutral".
Sep 20, 2014 | Health & Beauty
What do i do..mk6-mpj invacare joystick got wet and wont turn on
Hi, you can send it to me for testing , free , you only pay for the postage back...(UK only)
Regards
Rob
www.gewizrepairs.co.uk
Nov 22, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
Mk6 mpj joystick got went and wont turn on
Hello,please visit:www.Invacare.com & where better to be (the Manufactures).I hope this helped,Colin
Joy stick malfunction, error messages
hi, it could be that there is a small amount of water still in there, Please remove the unit and place where you dry your cloths etc? somewhere warm but not hot, warm and dry only, now leave for 24 hours. Also check the cable connections making sure they are clean and fit well.
RegardsGeWiz.
Feb 12, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
Unable to connect Joystick in Game Controlers
What game are you trying to play? Most newer games don't know about the old game ports anymore. That could be the cause.
Nov 11, 2012 | Microsoft SideWinder Force Feedback Pro...
Hi! I'm just going to ask regarding the joystick of my n73. I'm having problem with it, since I can't use it already. It seems like it is already pushed, like if I'm using it, I can't...
Hello there,
The problem with the phone is that the joystick is weak and is not sitting anymore on the phones board, it need to be replaced. That is what you have to do, they sell the joystick in stores or you can get a phone that no longer works and use the joystick.
You will have to take out the joystick by disassembling the phone, and reaching for it,then replace it with new one. That works all the time,if not the phone will be out of controll as the navigation button is what shows its functions.
Hope this helps
Goodluck
Elect_Comp
Aug 10, 2011 | Nokia N73 Cellular Phone
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
May 10, 2010 | Invacare Supply Group Invacare Pronto M51...
Sony Ericsson Joystick
Use WD-40 oil. I know it might feel weird but it really helps.
Works with all joystick SE phones.
Aug 08, 2009 | Sony Ericsson K850i Mobile Phone
Joystick turned off, won`t operate
Ok... that is a VERY Easy fix... all you do is get into a plane with the kneeboard and click controls and find it!
Feb 09, 2009 | Saitek Aviator AV8R Joystick
Health & Beauty Logo
26 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
