Question about Exercise & Fitness
How to lubricate my precor 9.33i - Exercise & Fitness
  • 914 Answers
Below are a couple of links to show how to apply a liquid lube or a powdered wax:
How to Lubricate Treadmill Using Liquid Lube Video How to Wax Treadmill Using Powder Wax Video
Posted on Feb 09, 2015
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
seconds
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
My 933i is tripping my house circuit breaker at higher speeds. I think there is more resistance in the belt (It's never been serviced).
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt monthly. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine. -
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
The following link will take you to our tech support page that contains some tips and videos on how to maintain your treadmill:
SPORTSMITH LLC
Sep 21, 2013 | Precor 933 Premium Series Treadmill
Hello, Our Precor 9.21si begins slipping after walking or running a few minutes. Seems to be worse the faster you go. After about 1 mile, the house fuse blows. What troubleshooting steps do you thi
This really sounds like the results of long term use without lubrication or wax between the belt and deck. Chances are you will need to replace the running belt and the deck or flip the deck if it has not already been done. The friction builds up between the deck and belt and caused the electronic components to overheat. The machine is shutting down as a precautionary measure. It will do this only so many times before the electronics are zapped. Start with the deck and belt. Hopefully the electronics are okay. With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Feb 03, 2013 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Precor 905e turns off after i run at 10 mph for about a minute
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
Jan 04, 2013 | Precor 905e 9.2 9.20 9.20s 9.1 9.2s Motor...
Power keeps cutting out when clients are running on it.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Apr 16, 2011 | Precor C956i Treadmills with HR /...
Have a Precor M9.1 treadmill which cuts off after about 5 to minutes of use. It can be reset immediately and will run for another 5 to 10 minutes before cutting off again. The belt is well aligned and...
Precor Repair Parts for 9 1 9 10 Treadmills SPORTSMITH net
Mar 22, 2011 | Precor 9.21 Treadmill
Treadmill works just fine for me. i am 100 pounds, my husband got on and it went out of control and he was trying to regulate it and had to get off. We have tried several times. It works for me not for...
Sounds like the unit needs to be lubricated, Its laboring under his weight thus the foot plant technology that the precor use cannot adjust properly go to Treadmill Doctor.com and you order the lubricant from their.
Apr 27, 2010 | Precor 9.31 Treadmill
My Treadmill shuts down after 10 mins on it. Can it be over heating. what could be wrong.
If you have not ever lubricated the running deck then I suggest doing so . What happens is that the lack of lubrication will tend to make the belt drag or stop . The lower board will register a excessive current thus shutting down. If the lubrication does work then you may need to replace the running belt and flip the deck if this process has never done.
Apr 21, 2010 | Precor 9.21 Treadmill
I have the Precor 9.31 and it is 4 years old. When I start going fast the power shuts off completley. I am 210 pounds and this happens to me, however my wife is 120 pounds and is not having a problom.
SOUND LIKE A LUBRICATION ISSUE DEPENDING ON THE MANUFACTURER NOW A DAYS SYN SILICON IS USED ON MOST PHENOLIC DECKS IF NO MAINTENANCE HAS BEEN DONE I WOULD ALSO CHECK THE FOR UNEVEN SURFACE AND THE BELT MAYBE TO WORN AND THE LUBRICATE WILL NOT BE EFFECTIVE , BUT ITS CHEAPER TO TRY LUBE THAN NEW BELT AND DECK. GO TO gymparts.com part# TM001 or call them @ 1-800-496-7278
Feb 03, 2010 | Precor 9.31 Treadmill
Exercise & Fitness Logo
80 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
