Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi EC 860 red light keeps blinking
Red light continually blinks..coffee stops dripping
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
dutchman05
  • 487 Answers
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Posted on Apr 16, 2008
  • 85 Answers
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
  • 81 Answers
SOURCE: The red Water warning light keeps blinking,even
It means ventilate, purge the air out of the system by turning on the knob, the pump should run .Keep it running until the red light stops blinking.If not there's a blockage in the line.
Posted on Jan 24, 2010
SOURCE: Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Posted on Jan 16, 2011
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Why does red light keeps flashing on dolce gusto mini me ?
In my case it was a minor detail: The capsule holder tray has a small magnet on the top right side, you can feel a light pull when you are inserting it in the machine. This magnet became dislodged from the capsule holder, and the machine won't operate and will give you a continuous blinking red light if the magnet is not in place; I found it when emptying a small bin where I put the used capsules. You just have to put it back in place with two drops of glue, or if you can't find it, just order a new capsule holder.
The picture shows the underside of the capsule holder and the magnet next to the slot it came from.
Sep 02, 2014 | De'Longhi EDG200T Nescafe Dolce Gusto...
There is a red light flashing thru all the icons underneath the controls
Run the hot water tap until the lights stop blinking. It is asking for the water circuit to be primed IIRC.
Sep 30, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I have a DCR902T coffee maker. The red ON/OFF light is continually blinking, and pressing the ON/OFF button does not turn it off. Disconnecting the coffee maker does not change the problem. No idea what...
This is telling you that it is time to clean the coffee maker. Press the minute and hour buttons at the same time and hold untl the light stops flashing. Take out the water filter and fill the water tank to 10 cups and add 2 cups of white vinegar. Put the water tank back in, without the water filter. Take out the permenant coffee filter. Turn it on and leave it until about half the water goes through. Turn it off. Let it sit for about an hour, then finish the job. Then, run 2 pots of clean water through. You are good. It will notify you to clean your system every 40 pots or so.
Jul 29, 2011 | DeLonghi DCR902T Coffee Maker
When machine turns on, red light blinks, no cycle
Hi
If it won't cycle and the red light blinks, it means that something is out of place. Usually its the drip tray not all the way in. It could be the brew unit is not locked in or the dredge drawer. Push the drip tray towards the back when the machine is on and see if it wants to cycle, then check the other ones until it does.
Apr 05, 2011 | Saeco Vienna SuperAutomatica Coffee...
Flashing red light
This is the machine's way of indicating that it is time to de-scale. It simply counts the number of times that it has been used to brew coffee, and after a set number of cycles, the light begins to blink. It does not interfere with performance, but it can be a major pain to tell when it is on/off.
To de-scale, they recommend you run a solution of citric acid through the coffee maker (diluted vinegar would probably work just as well), followed by three cycles of plain water to clear any leftover solution.
To get the red light to stop flashing, you need to press the "prog" and "drip/auto" buttons at exactly the same time. You don't need to hold them down, just need to time the press at exactly the same time. This resets the counter.
Sep 26, 2010 | DeLonghi Caffe Figaro BCO110 Espresso &...
The red Water warning light keeps blinking,even there is enough water supply.
Jan 23, 2010 | Starbucks Saeco Italia Digital Barista...
COFFE MACHIEN WON'T MAKE COFFEE
Hi
A blinking red light means that something is not in place. The usual subject is the drip tray. If it doesn't lock into place usually there are grounds behind it. The brew unit is an other one that doesn't lock in every time. To check, open the door and without pushing the "press" button, grab the handle and pull. If it comes out, that was your problem.
Jun 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee Makers & Espresso Machines Logo
1,032 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
