Question about Snom 821
Reset snom 821 password - Snom 821
Default snom 360
Maybe you have to install a "recovery" OS on the phone. You get it from the snom-website, but you have to use a TFTP-server on your PC. When you boot the phone, the display says something like "TFTP bootoing....press any key". Then you enter the IP-adrwess of your TFTP-server and some other information and the OS will be loaded to the phone. If you get this working, everything is set to factory default and you can update the OS to the latest version. All passwords are set to default-values (or empty - I do not remember now)
This sounds more complicated than it is :-)
Apr 26, 2014 | Snom Computers & Internet
Snom ONE SoHO IP address finding
The IP address cannot change if it is a static IP.Only dynamic IP address can be changed.You can check your static IP address in this site Ip-details.com .
Dec 29, 2012 | Snom One Soho Ip-pbx
Delete messages
how to take call off call forwarding
Sep 20, 2012 | Snom 821
HOW DO I UNLOCK MY SNOM 300 KEYPAD?
To lock or unlock a Snom 300 keypad you will use the * key. Hold this down until the lock icon appears and hold down again until lock icon is gone to unlock.
Jan 14, 2011 | Snom 300 IP Phone
My snom 300 phone displays NR help please
try resetting the vlan settings if that doesnt work ensure that the default gateway and dns settings are correct.
Dec 08, 2010 | Snom 300 IP Phone
Snom 300 does not renew ip address on DHCP
reset the vlan settings see if that does the trick
Nov 05, 2010 | Snom 300 IP Phone
I forgot the password and cannot access the web interface of snom 300, version of firm ware is 7.3.23, I have tried to reset it but it again asks for password. I have tried user name as 'admin' and...
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Jul 02, 2009 | Snom 300 IP Phone
Can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Jan 23, 2009 | Snom 300 IP Phone
How to reset a forgotten admin password on a xerox 4150
PRESS # AND ACCSES SIMULTANIUS FOR 3 SECONDS
PASSWORD 1934
Oct 01, 2008 | Xerox Office Equipment & Supplies
Snom 821 Logo
54 people viewed this question
Top Snom Computers & Internet Experts
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
