Question about Sony PlayStation Portable (PSP) Console
PSP won't turn on
PSP worked fine and then one day after charging it started up and would immediately shut down. Now when you plug it in nothing happens...no green light or anything. I tried using my younger sons charger and battery since i thought this could be the problem and still nothing (the battery and charger work fine on my younger sons). Any suggestions? Sue
  • Sue Davignon Jul 09, 2007
    Thank you inky! Tried to send a comment when I found it worked and wouldn't send...at least I don't think it did. You're the best! Take care--Sue
  • Sue Davignon Jul 13, 2007
    Now that I have gotten the Psp to work my son turned it on the other day and 1/2 the screen was black and it has lines in it. What is up with that? Any help?
    Sergeant:
  • 279 Answers
Also, there is a chance it's just a loose connection to the LCD. If a few pins aren't connecting, it can mess up part of the screen like that. More likely it's what Inky said though.
Posted on Aug 31, 2007
  • 691 Answers
You can try a hard reset. Do this hold the power switch in the upward position for over 10 seconds. This will cause the machine to reboot. Leave it alone for a few minutes then try switching it back on. You may have to flick the switch on twice to start her up again. If it still has a hard time try changing the battery for the one in your sons machine. MAKE SURE that all apps etc are closed on the PSP first and do the hard reset BEFORE you remove the battery on BOTH machines. Ensure PSP is OFF before removing battery. It is possible the battery has been overcharged or just given up. If the console operates with the other battery you know you need get a fresh one. Consider getting a high power one for extended life. Let us know how you get on. May have more info for you.
Posted on Jul 03, 2007
  • Inky Fingers
    Inky Fingers Jul 05, 2007
    Any luck?
  • Inky Fingers
    Inky Fingers Jul 22, 2007
    Sorry for the long delay - I was off on holiday
    Sounds like it could have a problem with the power distribution board. It's a small PCB where the switch mounts. Or it could be the board that controls the LCD. Either way I suggest you get a repair center to have a look at it.
    Switch board is approx £5.00 and fuse for the LCD backlight is a bit less. The board for the LCD is a good bit more expensive if needed. Labour will be added.
PSP charged all night and will not power on
You're not being clear.
You say "I get nothing"
Do you get a green light? Or no green light?
What if you plug it in? Do you get a green light if it's plugged in with no battery inside?
If you get a green light with the battery in but nothing on the screen, your PSP is bricked.
If the PSP works while plugged in but not with the battery it's either having motherboard problems or the three prongs on the back of the PSP are not making good contact with the battery.
Mar 16, 2010 | Sony PlayStation Portable (PSP) Console
Psp fell ,turn psp on.green light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
My psp green light turns on for a little while and then shuts down. The screen doesn't turn on at all when I try to turn the PSP 3000 on. I fully charged it and nothing happens. Please help
that usually means youe psp is bricked when that happens its usually a factory default return it to the place you got it and call sony about your problem they will repair or replace it hope this was helpful:)
Nov 16, 2009 | Sony PSP-3000 Silver Console
PSP will only power on about 10% of the time...
Just send it into to sony or buy another one sorry bud......
Oct 07, 2009 | Sony PlayStation Portable (PSP) Console
Psp is not turning on.
it could be that the battery needs replacing
May 15, 2009 | Sony PlayStation Portable (PSP) Console
Psp wont turn on
the downloads dont matter.u change the battery and if it doesnt work take it to a shop.if u have spill water on it open the psp cover and everything and for 2 days put it in the hot sun
Apr 25, 2009 | Sony PlayStation Portable (PSP) Console
Green light is on but nothing on the viewer
Ok it is bricked so what you need to do is: Take it to a shop, or get a Pandora's battery, email me when you have a pandora's battery
Feel free to E-Mail me: Thomashedderwick@hotmail.com
Aug 10, 2008 | Sony PlayStation Portable (PSP) Console
Battery appears charged, but computer will only run when plugged in
does your battery have one of those charge indicator panels on bottom?
also, it's possible that the connection from battery to the internals is shot..if that's the case, then you're looking at a major motherboard swap
May 15, 2008 | Lenovo 3000 V100 Notebook
Psp
Check to make sure the battery is charged. If the battery is low or almost out, it'll start & shut off like this.
Jan 07, 2008 | Sony PlayStation Portable (PSP) Console
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
102 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
