Question about Dell 962 Photo All-In-One InkJet Printer
Printer makes a loud grinding sound when trying to print
It sounds like the gears are stripped. This is a work printer and info on whether or not there is a warranty in place is no where to be found. Any ideas on whether or not this is something fixable or do we just need to trash it and buy a new one.
  • 186 Answers
I am pretty sure there is a 90 day warranty but you should call Del to find out. You can try lifting the cover where the ink cartridges are. Look and make sure there is nothing obstructing the print head from going left to right. Also, make sure the cover holding the ink cartridge is snapped down tight. Good luck John
Posted on Jul 03, 2007
SOURCE:
Printer stopped working. makes loud cracking noise.repeats movement and noise
Sound could come from either a stripped gear or toothed belt. Try printing a blank page or two, if it doesn't feed then the above is a good possibility.
Sep 23, 2011 | Kodak ESP 5 Printer
HP CP3525 loud grinding noise when calibrating after printing
Sounds like you have a stripped gear somewhere. Probably somewhere in the paper drive assembly. Take it to your nearest printer repair shop, because tech support may not be much help with that.
May 20, 2011 | HP CP3525N Color LaserJet Printer
HP Laserjet P3005dn printer makes a loud grinding sound while printing. Prints OK, but users are annoyed by the sound
Replace the fuser and the fuser drive gear. When you order the fuser make sure that they include the gear.
Nov 22, 2010 | HP LaserJet P3005dn Printer
HP2420N printer makes a loud grinding sound when printing
This printer had change made to some drive gears. They wear down and cause this noise. If you can find a technician to replace the 3 gears it can be inexpensive. We do it for under $150 with labor and parts.
Apr 15, 2010 | HP LaserJet 2420 Printer
Grinding noise when printing
GEARS ARE NOT MOVING FREELY. CHECK GEARS
Apr 12, 2010 | Brother HL-2070N Laser Printer
Printer makes grinding noise and not printing
sounds like the rubber band in side the printer has jumped a tooth which is why it is grinding bud have it repaired or get another
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
LOUD clicking sound and no print
plz give me a solution when i gave a print command there is two light one is green and second is orenge light this two lights are constend so plz give a solution.
May 04, 2008 | HP LaserJet 1020 Printer
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Makes loud sounds
I had the same problem with the loud grinding sound. The gears on the cartridge(s) is not turning but rather stripping creating a grinding sound. Reinstall all of the toner cartridges. If that doesn't work, pull each cartridge out and manually turn the gear on the cartridge. If the problem persists, you may need to purchase a new toner cartridge.
Dec 04, 2007 | Brother MFC-9420CN All-In-One Laser...
Dell 962 Photo All-In-One InkJet Printer Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
