Question about RCA HD52W58 52" TV
Turn tv on and it just say bloop bloop bloop then turn self off
Tv will not come on just make 3 blooping noise then cut off
  • 3 more comments
  • sick-thing Jan 22, 2009
    I have the same problem. sounds like it will turn on then goes off. Does it 3 times.
  • Anonymous Feb 03, 2009
    I have this same problem
  • Anonymous Mar 03, 2009
    When the TV is cold, it will not turn on, when I finally get it on, it will stay on after it warms up. Can anyone help?
  • bren1958 Mar 07, 2009
    i turn on the tv and it never shows picture then goes off and on by itself and then finally turns itself off. So a picture never comes up. Please help as this tv is only 2 years old,OUCH!!!!
  • dvmccracken Mar 09, 2009
    a tv repair shop took my hd52w59 to shop for repair.they said the green color tube was shorting out,causing the power circuit board to shut the tv off after three trys of trying to power up. they said it would cost to much to repair tv. tv is only 3 1/2 years old,guess they don"t make rca tvs like they used to
Same problem
Posted on Feb 09, 2009
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
Too noisy hard to watch tv or sleep
Raise the setpoint a couple of degrees, this will cut down on the noise of the compressor, put fan speed on low and that should cut down on blower noise.
Make sure you have some rubber pads underneath the unit and that should cutdown on vibration.
Jul 03, 2010 | NewAir AC-12000E Portable Air Conditioner
Loud schreikin noise and cuts off.
it sounds as thought the main-board of the TV is arching or shorting out. This is due to a faulty component in the power section of the TV . It is about to completely go out.
The main board need to be checked for bad components.
Apr 23, 2010 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
How do i stop my radio from making that bloop bloop noise after i key it
You are either describing a CALL TONE ( The Call Tone obtains others’ attention before you start talking) or the ROGER BEEP (When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.)
To shut off the roger beep, hold in the plus + button while turning the radio on.
The CALL TONE may or may not be a feature of your T5210 radio. I am unable to open the online manual for it to tell for certain. If it does have a CALL TONE feature you would access it by pressing the MENU button until you see a "CA" on the screen along with a number. Using the plus or minus button change the setting to zero, followed by pressing the menu button or the PTT button. The zero setting is equivalent to OFF.
To
Oct 01, 2009 | Motorola Talkabout T5210 2-Way Radio
Phone will not ring or connect
Here are some things to check...
First call the phone company make sure no outages (I am sure you have already done this)
Try another phone in the same jack and other jacks in your house.
If you go outside you will find a service panel. There is a customer side and a phone company side...you can usually open with a regular screwdriver...
You will find a phone jack...plug in any old working analog phone...if it works from there...the problem is in your house...if it does not work call the phone company....the problem is on their end.
Good luck my friend
Seek PC Repair
Feb 09, 2008 | Linksys EtherFast Cable/DSL Router
RCA HD52W58 52" TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
