Question about Hitachi CP-S210 Multimedia Projector
Why is my lamp green? - Hitachi CP-S210 Multimedia Projector
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Replaced lamd power and lamp light are green for
Yes you need to replace lamp,so you buy a new lamp.
Dec 14, 2009 | Sharp Notevision PG-A10X Multimedia...
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
Lamp wont light. Green then Red on power. Orange
hello The lamp cover is ajar. Firmly replace the cover
shaun
Oct 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Hitachi CP-S210 Multimedia Projector Logo
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
