Question about KitchenAid Dryers
Kitchenaid prestige keys677eqo timer works but drum won't turn
Maytag317
  • 1136 Answers
SOURCE: our 12 year old kitchenaide prestige dryer's timer
Hi, If the dryer heats in the automatic cycle and the timer still does not advance, try using the time cycle. If the timer still won't advance, you will need to replace the timer.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
Posted on Feb 12, 2010
ftw1952
  • 10319 Answers
SOURCE: I have a Kitchenaid Prestige
a loose screw inside will need to be tighten down so the screen will go fully in. remove the hold down screws from the top of the screens insert housing and take a flashlight to see were that screw is. some can be tigthen down without tearing the outer dryers panels apart
Posted on Nov 18, 2010
jumptrout51
  • 3361 Answers
SOURCE: drum won't turn, dryer turns on and every thing
Replace your broken belt.
Posted on May 14, 2011
heatman101
  • 43501 Answers
SOURCE: Kitchenaid gas dryer won't ignite
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Sep 11, 2011
SOURCE: asko dryer 7005 model, heat element work but the cylinder or the drum won't turn
Can you tell if the drive belt is still in place?
Posted on Mar 03, 2012
My kitchenAid clothes washer won't always agitate but the timer will finish the cycle
Possible that the timer is not switching the circuit to the designed cycles and so it does not go to the spin mode. It can be due to loss in mechanical contact due to worn out points or dirt accumulation. Use a cleaner, WD40 , could be good to try on the timer before you can estimate the cost of a timer.
Jan 20, 2013 | Washing Machines
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
I have power & the timer still works.... But the
check and make sure both breakers in fuse box are still on if they are then look for abstruction where door closes
Sep 08, 2012 | Dryers
LG WM3431hs drum won't turn on dry cycle
Broken drive belt tho your model number is not for a dryer.
Feb 04, 2018 | LG WM3431 Front Load Washer / Dryer
My clothes dryer timer won't work and it won't heat up
Dear Sir:
See this possibles causes:
1) Do not work
Power house: test for blown fuse or c. breaker tripped, replace or reset
door switch: test for open or defective see the video
thermal fuse. test for open or defective see the video
wiring: see for burn or breake test for continuity see the diagram
heating element: test for burn or open see the video.
God bless you.
May 23, 2012 | Dryers
How to start kitchenaid dishwasher
1-confirm power make sure breaker is not tripped or fuse is good and no tripped GFI's (no power obviously it won't work) 2-confirm water is on (the timer has a delay that it powers down during it's wait for the unit to fill with water 3-make sure the door is fully closed and latched properly (the door has a safety interlock to prevent the dishwasher from operating while the door is open -- think water sprayed everywhere) 4- beyond this if it is a new install and has never worked call your installer back
Apr 08, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
heatman101
Sep 10, 2011 | KitchenAid Dryers
Have a KitchenAid Prestige Top Load Washing Machine (Model: KAWs677EQO). It makes noise during the spin cycle and the drum moves when it comes to a complete stop after the spin cycle. Otherwise, it works...
I had the same problem 1 month ago, its probably the motor coupling for the direct drive. Its a small rubber Ring + a plastik drive. Its easy to change and not expensive.
Here the link for the part
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
May 01, 2010 | KitchenAid KAWS750L Top Load Washer
Our 12 year old kitchenaide prestige dryer's timer gets stuck and it does not shut off automatically
Thanks
Vic
Feb 12, 2010 | Dryers
Dryers Logo
44 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
