Question about Garden
How do you hook up detergent to a macallister pressure washer
4 Suggested Answers
  • 313 Answers
SOURCE: hooking up detergent to pressure washer
detergent can only be **** from the container only on low pressure.
Posted on Jul 08, 2008
  • 1383 Answers
SOURCE: Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Posted on Dec 01, 2008
  • 199 Answers
SOURCE: Troy-Bilt pressure washer will not pick up cleaning fluid
put the washer on low presure it will pick it up then. doesn't make since but that is how they designe them. thay make a high presurre add on device i have seen them them in local home inproverment places.
Posted on Jul 20, 2009
Hi,does anyone please have a service/maintenance manual for a MACallister mac 3 electric pressure washer
Google search gives this
http://bsintek.basco.com/MDEXResultsPages/PDFDisplayPage.aspx?fileName=ilmtFI25YmTPq79DteBc
Apr 08, 2015 | General Washing Machines
I need to know where to put detergent in the pressure washer I have no model number
These units come with a detergent bottle that attaches to the spray wand. The manual describes what detergents to use and the attachment reduces the pressure and siphons the right amount of detergent from the container. It is not a good idea to try to run detergent through the pump.
Here is a link to the operating manual for a similar pressure washer.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/pw0501400.pdf.
Mar 05, 2015 | Coleman Powermate DuraBuilt 1400 PSI...
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
How do i change attachments on macallister pressure washer
I assume you have a QD quick disconnect on the end of your wand...it is a brass piece that slides back the collar allowing you to pull out and push in your tips as needed...good luck
Feb 18, 2015 | Garden
Spares for macallister MAC360PWA
looking for a pressure hose for mac allister 360pwa
Apr 03, 2013 | Garden
Macallister 3 Electric Pressure Washer manual
manual for mac 3 pressure washer
Oct 31, 2010 | Vacuums
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Water should come out other side of pump.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
How do I hook up and use soap on model 020228 pressure washer
There are different nozzles. One for detergent, Max, General and Delicate. The detergent one is more a less a soaker its opening is the biggest (less producing pressure), it's the one that must be used to siphon the soap out of the container none of the other tips will allow to siphon. I hope this is helpful to you please rate this answer on how helpful it was. Good Luck and have a great weekend.
Apr 01, 2010 | Briggs Stratton 020273 Elite Series...
Hooking up detergent to pressure washer
Jul 05, 2008 | Karcher 2500 PSI Pressure Washer
B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Oct 18, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
561 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
