Question about Homelite Plumbing
How to remove impeller from homelite AP-125 water pump
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: have a homelite AP-125 -
Your best bet is to ask Homelite directly for the pump curve. Since Homelite does not appear to offer it anymore I could not find anyone who published the information, hence the referal to Homelite. A typical pump curve for a small pump like this will show GPM or GPH based on several discharge heights. You do not need to consider the overall run of pipe or hose but only the total change in height. In other words, pumping thru 150' of 3/4" hose up an incline that has a total rise of 12' would end up delivering the GPM for 12' on the curve or something very close anyway.
Contact Homelite here.
John
Posted on Jan 04, 2011
  • 70 Answers
SOURCE: My late husband bought a
usually on the fuel cap it has the mixture,usually 40 to 1 is a safe bet,a little too much oil in the mix is better than less
Posted on Jun 12, 2011
  • 643 Answers
SOURCE: parts for AP 125 water pump (Homelite ) that is no
Homelite still has some parts for this pump
go to http://hcpi.arinet.com/scripts/EmpartISAPI.dll?MF
search for AP125 with no space
pick your model
parts list will come up
Posted on Jun 28, 2011
I cant get the impeller off on a homelite trash pump,it is stuck
If I remember right that's a threaded shaft so it's on to the right and off to the left.
but they can be a pain to get off, so apply some heat to the impeller close to the shaft, this will cause the impeller to expand an ease in its removal, the trick is to not heat the shaft and work quickly, use a wood block and a big hammer to hit on veins close to the hub and alternate frequently between them.
Jay the pool pump motor repair guy in longwood Florida'
if'n yer local bring it by and I will give you a hand.
Jay
https://www.partswarehouse.com/Homelite-RTP3-Trash-Pump-UT-01577-s/13044.htm
Mar 08, 2018 | Pool & Spa
Ap-125 homelite gas watwer pump pull cord replace
few years late but here: guessing your problem area is the impeller blade? remove impeller blade by turning clockwise ( i put a screwdriver in the pull cord fin to stop shaft). Then remove spring around rubber gasket behind blade (then rubber gasket pulls off shaft. everything else just UN-bolts. Just figured it out myself today.
Jan 01, 2013 | Homelite Plumbing
Parts for AP 125 water pump (Homelite ) that is no longer being manufactured.
pick your model
Jun 27, 2011 | Homelite Plumbing
Have a homelite AP-125 - UTO1709 F, want to know how far it can pump water uphill
John
Jan 04, 2011 | Homelite Plumbing
Engine problem
Water coming out of the hole is to indicate that the pump seals need to be replaced. Some water is probably in the gearbox now. If the oil is whiteish you do. Pull the right case cover then remove the pump cover and the impeller then replace the seals. Remove the liquid gasket so that the hole is open again. You can see a parts diagram at www.babbittsonline.com Click on the red "OEM PARTS" tab. Items 6 and 7 are the seals separating the water from the oil. Put a wrench on the impeller shaft next to the gear, then unscrew the impeller as if it were a screw. It would be good to replace the gasket (item 10) as well. Please take a moment and rate my answer to your problem.
Jan 03, 2010 | 2003 Yamaha YZ 125
I have a Homelite recirc pump AP-125. Motor runs
usual if the pump is dry you need to try bleed get some water to the pump. either pouring some in the lift pipe some pumps have a bleed screw to pour into to get it pumping. if it still wont could be the fins in the pump that are not working proper
Sep 26, 2009 | Homelite Garden
IM TRYING TO FIGURE OUT HOW TO REMOVE IMPELLER TO REPLACE SEAL 2001YZ 125 LEAKS WATER
The impeller screws onto the impeller shaft. Go to the site below and you can see a parts diagram. You will select the brand, year, model, etc... It has the part numbers and prices.
http://www.babbittsonline.com/pages/parts/viewbybrand/1/Yamaha.aspx
There are actually two seals. Are you sure the leak is a bad seal and not the water pump gasket or a cracked/broken housing cover?
Please post a top rating for this solution. Thanks! :)
May 19, 2009 | 2004 Yamaha YZ 125
Removing water pump impeller
you might have to split the case to get to the back side of the impeller.
Mar 28, 2009 | 2004 Yamaha YZ 125
Plumbing Logo
385 people viewed this question
Top Homelite Plumbing Experts
DROPNDEAL
DROPNDEAL
richie46
Gil Shultz
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
