Question about Toshiba A205-S4577 Notebook
Help my computer was working fine until i tested a friends charger from a similiar laptop to see if it was working and when i did it made a pulsating noise and i unplugged it right away. when i hooked my charger back to it the computer was working fine but not charging. so i shut it off and it will no power on or anyhting at all now. What do you think I did?
  • 382 Answers
First you should have checked the voltage and amperage on your friends charger. Sounds as if it was not correct for you computer. Pulsating sound often occurs when too much amperage is applied. Sometimes you can get lucky and just mess up the battery. Try removing battery and pluging in your power cable to see if you can atleast get your system running again. If not the result will not be one that you will like very much unless you were about to be replacing your laptop. Always make sure you read the labels on any replacement power cords.
Posted on Jan 26, 2009
6530 aspire laptop charger gets really hot and doesn't stay charged for long
sounds like the battery is going bad on you . chargers will get hot when they have to work too hard as when the battery is not taking the juice .
Aug 03, 2015 | Aspire Computers & Internet
Blinking laptop charger
Your laptop charger may be dying, do not use this kind of laptop anymore until you test your laptop using a good working laptop charger. If you don't have it, then you can buy it online (eBay.com is a good source), or you can go to local computer store to buy a good quality laptop charger.
Mar 06, 2014 | Samsung Computers & Internet
My M11x Alienware Laptop beeps 6 times at start
No a good idea to use a Cord/charger until you verify the power specs, they must be the EXACT same power specs in DC volts and milliamps , you may have fried a component/components in your Mobo. This may help diagnose the issue: http://forum-en.msi.com/index.php?topic=86906.0
Jan 25, 2013 | Dell Alienware M11x Gaming Laptop Computer...
My charger is plugged in to my MSI U130 netbook and in to the wall but is not charging at all. It isn't coming up with the little image to show the charger is plugged in, I have tried plugging the...
There are two very common faults that often cause this.
One is a damaged cord on the charger.
The other is a damaged connector on the laptop.
You will need a volt/ohm meter to test the charger. If you don't have one perhaps a friend does?
If you think you may have use for one inexpensive models are available and are fine for simple jobs and occasional use.
The charger's output voltage will be listed on the charger body. Look for something like:
OUTPUT: +19V 2000mA
For your purposes all you need to know is, is the charger putting out the proper voltage and is it steady?
If the charger is working then it is very likely the connector on the laptop.
These are not difficult to fix if you have experience repairing laptops.
Most computer repair people do this all the time for a reasonable set fee.
Hope this helps
Jul 03, 2011 | Computers & Internet
My laptop charging port is not working properly. My Charger is running properly but the charging port of the laptop is not working.It is not getting charged.Now the laptop is totally off and now i cant...
There are three possible parts of the computer which cause the problem.
1. ac adapter or charger
2. battery
3. motherboard
The charger is working fine which leaves the battery and the motherboard to be the possible reasons for that certain problem. What you need to do is to check which one is really the part that's causing the problem.
Here's what you need to do:
1. Remove the battery from the laptop.
2. Turn the computer by using the charger alone. If it turns on then, the battery needs to be replaced. If it doesn't then it's a motherboard problem which is a very complicated situation. You need to see a computer technician for a motherboard problem.
Apr 19, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
I took out the battery from my mac lap top held the power button for 10 seconds, I put back the battery in the laptop. However my laptop still won't turn on. What should I do?
You gotta trouble shoot. Take the battery and charge it on a friends computer or go to the Apple store and have them test it. If the battery is good, then your next step is the charger. Do the same thing with it-take it to the Apple store and have them test it or test it on your friends laptop. If the charger is good then the next culprit is the computer. Put a working known good battery in the computer and see if it turns on. If no, take the battery out and just plug in a good working known charger and see if the computer turns on that way. If still nothing, then you have to take the computer in to the Apple dorks and pay their hefty fee and have them fix it.
Nov 10, 2010 | Apple PowerBook G4 Mac Notebook
Dell latitude 400 charging problem
Your english is actually above average!
For you to get the best solution to this problem, I'll suggest that you should just try and get a friend, or a technician that has a charger of the same type, i.e a Dell Laptop Charger, to test it with. Now, if it still doesnt work, then you can try and swap the Battery with a working one also. All these are just to clarify things for you and to teach you the easiest way of troubleshooting it yourself.
Then If the new charger charges it, it means you just have to get a new charger, and if the Battery swapping is the one that works, then you might have to get a new battery too.
At the same time also try this quick solution :
Remove the battery from the back of your laptop, and power the laptop without the battery inside. If it works this way, then just try and get a new battery instead.
Hope this helps you out!
Goodluck
Jul 13, 2009 | Dell Latitude D400 Notebook
Charging Problem
go back to old bios if u can
Jan 21, 2008 | Dell Latitude D600 Notebook
Toshiba A205-S4577 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
