Calibra 16 manual - Heating & Cooling
Im trying to find an owners manual for a 1991 Holden Calibra 2L.
Look on ebay there are so many on there, also you can post a find it for me on there also , best place to find this stuff , good luck
Mar 19, 2014 | Vehicle Parts & Accessories
Have replaced brake light on my calibra but will
calibra??? sounds like there is a ground problem.
Oct 14, 2009 | 1999 Chevrolet Silverado 1500
Vauxhall calibra will not start ignition light
the flash indicates a code count the number of blinks usually a shot blink 1,2,3and so on followed by another series of blinks and it may even give 2 or more codes depending write them down and look the code up on line it could indicate that a door is open causing this issue **** as a sensor is not reading correctly a few other ideas to start with its just a matter of breaking it all down one section of area at a time to figure out the cause
Aug 29, 2009 | 1999 Chevrolet Silverado 1500
Please Email me at paul_bryant@hotmail.co.uk and I will tell you how to by-pass the imob'
Aug 29, 2009 | 1996 Volkswagen Cabrio
Go to GM Vauxhall website and it will indicate where to archive User Handbooks, or invest in a Haynes Manual, which as a new owner of a late model, I would suggest, be a better and safer bet. You then have 99% of Repair and Fault Finding information. Cheaper than a Garage if you have DIY expertise.
In the UK, about 25 GBP.
Regards,DT
Nevada, USA
Aug 29, 2009 | 1993 Volkswagen Cabriolet
Hi I have a Zebra ql220 printer that prints about 4 or five blank labels in between barcodes. Is there a way to manually adjust this via the printer. I got a message on one printer about bar gap sense not...
Press and hold feed button for 2 -3 seconds and switch on printer.Printer will calibra and print test page .if problem is not solved Go to printer menu and select ribbon and media calibration.it will calibra te printer and problem will be solved
Aug 03, 2009 | Zebra Printer 140-751-00000
V6 calibra engine pinging
using that high of octane fuel can cause the problems you might be having. using a higher octane is great but higher octane means higher cylinder pressures which pulls a very high demand on th ignition system, you need the ignition system to overcome aif/fuel and compression/cylinder pressures. try lowering the octane of upgrading your ignition system. the kocking/pinging you are hearing is incomplete combustion sounds. hope this helps
Jun 05, 2008 | 1995 Saab 900
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
