Question about HP LaserJet 1000 Printer
LaserJet1020 Crystal Reports on Forefront Accounting
Can't print reports without going to "Preview" first. Software Support says I must have a Unicode or "Host-Based Printing" driver. HP support pages state that LJ 1020 is "Host-Based" Still we get blank pages coming out of printer when we print--unless we click print from the Preview screen
  • 432 Answers
I found this document setting up Crystal Reports for your printer. I hope this helps. http://support.businessobjects.com/communityCS/TechnicalPapers/cr_printer_driver_options.pdf
Posted on Jul 04, 2007
  • Faye McGee
    Faye McGee Oct 29, 2012
    Couldn't find the answer on this website nor the question, but managed to get photo printed by setting photo tray & auto paper selection , but 4x6 size. Thanks.
SOURCE:
Crystal reports prints ###### instead of data. What does this indicate?
This is cause by the column size being to small in the print area.
Change the cloumn size or resize the column prior to printing to fix this. You may have to do this several times before you get it to print correctly.
Oct 10, 2013 | Crystal Decisions CRYSTAL REPORTS 9...
The request could not be submitted for background processing
apo ke he nyo nih yob??kome doh make ko??
nate babi sggh mat/minoh saleh nihh..jubo ite..
Jan 11, 2010 | Crystal Decisions Crystal Reports 10.0...
Printing previous reports in MYOB
save file into a .ZIP file then un Zip the file and it should help to change things or print reports. BUT, ALWAYS BACK UP A COPY OF YOUR FILE FIRST.
Mar 08, 2009 | Myob Accounting Plus (BPJUBC00) for PC,...
Looking for information - for my 10th project ...
Tally - An Integrated Enterprise Solution with Complete Accounting, Inventory and Reporting capabilities.
Tally provides a total solution that helps you to manage your accounts and inventory. Its vast array of management reports puts you on top of your operations be it a small business or a large one or even a non-profit organisation.It is a package introduced along with VAT feature..
Accounting Features :
1)Accounting without CODES
2)Unified Ledgers
3)Complete Book-keeping
4)Comprehensive Accounting
5)Multi-Currency Accounting
6)Receivables and Payables
7)Ratio Analysis
8)Budgeting, Auditing and Security Control
9)"Scenario" management
10)Unlimited Cost/Profit Centres
11)VAT and Sales Tax handling
Inventory Features ::
1)Multi-location Stock Control
2)Comprehensive recording of stock movement
3)Variety of management reports
4)Aged stocks Analysis
5)Batch- related stock reports
6)Re-order levels
Aug 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Crystal reports version 8.5
I'm not an expert in Crystal Reports, however you might find my info and experiences to be of some use with your question. I've been working with VB6.0 for some time. One day I decided to checkout Visual Studio 2008, (which came with crystal reports) I decided I didn't like it and removed it from my computer. It was after the removal of crystal reports that my computer went to hell. Every program I tried to install since it's removal was not being allowed, also every program I tried to uninstall was not being allowed. After some research I found out that Crystal Reports was the culprit. It has a management package that was designed to protect it's rights management. Simply stated.....it was governing parts of my registry by setting certain parts of my registry key permissions to, "read only". I ended up having to use the administrative tool in Windows XP and reloading default permissions through an existing INF file thus resetting every registry key back to it's default read/write state. I would not recommend you do this. Doing so may harm your existing install of Crystal Reports. What I would do though if I was in your situation, would be to change just the one key that pertains to your .tmp file location in regedit. My guess is it would be located HKLM under software. You can change any key permissions by simply right clicking any key and go to, "permissions" However, if i'm guessing right, Crystal Reports has a backup mech. that would not allow you to change the key permissions even in regedit. In wich case you'll have to use a utility like ::.HERE.:: and create a custom bat file for just that one key. You can try contacting Crystal Reports directly but i'm quite sure they'll just tell you to kindly, "get bent" lol. This method of protection serves no purpose other then to protect their software from being pirated. So i'm 99% sure they won't help you in the matter that you need. Changing permissions to registry keys back to default would negate their program protective measures. From the problem you described i'm 90% sure that is exactly what is going on due to what I already know about the protection measures of Crystal Reports. Any file that is being generated with Crystal Reports, temp or otherwise is now governed by Crystal Reports through your registry, through a registry like firewall, also run by Crystal Reports. This is why you're getting Access Denied when you try to right click the file and delete it locally. You have two options.
1.) Become submissive and a slave to their tech support and wait for them to come up with a solution that will allow them to maintain control over your registry, with a patch of some sort provided by either Microsft Visual Studio or through Crystal Reports directly that will resolve your particular issue.
2.) Setup a dummy computer install all the crystal reports programs on it. Get it all setup, then do a full registry reset (from that link i posted above) and see if you can still use crystal reports after the full registry reset and if that truely resolves all the access conflicts. If so then apply it your main work machine and once again become the master of your registry.
Hope that helps,
9x
Aug 26, 2008 | Computers & Internet
Can't print to old applications
The issue your having is with the Operating system compatability. The HP 3055 is compatible with 98, ME, XP, Window 2000 and forward. It won't do windows 3.1 or 95 well even if your computer will, the disconnect comes when the software is sending old print commands to a new style print driver.
Your best hope is to download and install the HP Printdriver for Windows 98 and try it as it's the most tolerant of old gear. Download the PCL 5 as the PCL6 is too new and probably not going to work.
As an alternate try to download each of the printdrivers for the differnt era windows and try them. It's a hard problem that may not have a solution other than upgrading the accounting software.
If it's simply a connection problem, they do make a USB to Parallel addaptor which may help you with the physical connection issue.
Here's a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=4&submit.x=3&lang=en&cc=us
Hope that helps you.
Aug 24, 2008 | HP LaserJet 3055 All-In-One Printer
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
186 people viewed this question
Clive
Clive
Thomas F. Schneider
