Set up box
Where can i obtain a samsung set up box to allow my tv to ercieve hd tv
    Genius:
  • 1,199 Answers
You dont need a samsung set up box! you can use any model and they are available at Wall-mart stores and radio shack stores!
Please rate this response and help us keep this area free!
Thank You!
Posted on Jan 21, 2009
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Samsung 40'' tv can't get High Def when i connect to my cable plus
make sure your cable box is hd compatible, also depending on the cable box you may have to go through your settings and change the resolution and also change your settings through the menu's on the tv itself. what type of cable box do you have? is it a satellite box? which provider?
Apr 04, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
I have HCL5515W tv. Want to convert to HD tv.
Not without the box, HDTV didnt really made an appearance except in the past 5 years
Jan 18, 2009 | Samsung HCL5515W 55" Rear Projection...
I was wondering what is the typical ideal set up in terms of picture settings to obtain the best picture from my 46" samsung 6 series. It is currently connected to my sky box (not HD)through a normal...
If you are not connected to HD, pixelation can easily occur, especially if you are using an analogue connection. Here is a list, from best to worst, of how you should connect the video on your system.
1) BEST - HDI cable between the TV HDMI in and the sky box HDMI out. This is a full bandwidth digital audio and video connection.
2) BETTER - S-Video between your TV and sky box (with L & R audio)
3) GOOD - Component Video with L & R audio
4) STANDARD - single video cable (yellow) along with L & R audio
5) standard coax
These are listed, as stated, from best to worst quality. If you are not using a digital connection (HDMI), then pixelation can be expected.
Sep 03, 2008 | Samsung Televison & Video
HD Reception
Do you have an HD box?
Aug 11, 2008 | Samsung Televison & Video
Hd set top box wont work with samsung plano crt
do you have cable
satellite or antenna???
Jul 30, 2008 | Samsung TXN3245FP 32" TV
Hd box
First of all I don't believe that this is an HD set. The coupon is for a converter that will allow an analog TV to receive digital broadcasted signals over the air. If this TV is connected to either cable or satelite, the converter box is not needed.
Dan
Jun 24, 2008 | Sansui COM3101 13" TV/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
