I have the logitech bluetooth keyboard with the separate number pad (not connected but came with it). I love it and it's worked great, but it suddenly stopped working a couple of days ago. I switched the batteries and pressed the connect button on the bottom. Am I doing something wrong? I really hope we can get this to work. My job depends on it! Thanks in advance, Erin
  • 8 more comments
  • erin858 Jan 21, 2009
    I've already done that a million times...any other suggestions?
    Yes, I checked the batteries, the receive and pushed the buttons. This usually only happens when the batteries are low. I used brand new pack of batteries and just in case they were faulty I tried another pair...no luck. I'm not sure if the receiver should be lit up...it's not! But it is plugged in.
    Yes..it's been 3 days now. But I'll try again.
    I got it to work!!!!! Thanks for you help and time...not sure what was wrong. Maybe all I needed to do was ask for some help. Best, Erin
  • erin858 Jan 22, 2009
    One more problem! No it's saying that I don't have a network connection. How do I fix this?
    I've already done that and the batteries are in the right way and I've rebooted my computer
    Oh sorry, I read the message above. A bluetooth jump drive that came with the keyboard. Everything's plugged in though.
    How do I uninstall the keyboard and re-install?
    how do i reinstall?
    i would have to find it. Thanks!
    Master:
  • 413 Answers
You have to push the connect button on the keyboard mouse and the receiver to reset all of them. It sounds like you just have to push the button on the receiver and the keyboard
Posted on Jan 21, 2009
  • 7 more comments
  • Dan rogers
    Dan rogers Jan 21, 2009
    Are the batteries in the right way? And is the receiver plugged in?
  • Dan rogers
    Most of them have a light on them when you are pushing a button or moving the mouse. Have you restarted the computer since you changed the batteries. That may be all it needs.
  • Dan rogers
    From what i read on the forums whenever you have a problem with this set-up you will probably have to reboot. I'm glad i could help and please don't forget to rate your solutions here on fixya
  • Dan rogers
    Dan rogers Jan 22, 2009
    How are you connecting to your network?
  • Dan rogers
    Is this about the network?
  • Dan rogers
    It really sounds like you are going to have to uninstall the keyboard and mouse and re-install them after a restart. Sorry this became such a pain in the neck'
  • Dan rogers
    go to start>control panel>system>hardware tab>device manager.
    Once in there right click on the keyboard and mouse and select uninstall or remove hardware.
  • Dan rogers
    When you boot the computer back up go back into the hardware manager and there will be a button to search for new hardware. Push that button and the computer should detect the device and you will install the drivers as normal. I'm assuming you have the driver cd that came with the equipment, right?
  • Dan rogers
    Just install as you did when you first set it up and you should be good to go.
How to use the @ sign on Logitech keyboard K480 Tried using the shift key but only get the option of inverted commas or apostrophe
You will need to set the correct keyboard on the PC. Alternativly try shift and the number 2 (on the top row of keys NOT the number pad)
Sep 05, 2016 | Logitech Bluetooth Multi-Device Keyboard...
Logitech Wave K350 won't boot with num lock on
Have you changed or updated anything else on your system? Added any other Bluetooth devices? I have the same KB, always boots with Num lock on. It worked with both Vista 64 and now Win 7. Maybe the driver and the specific USB port combination is not working. Try plugging the BT antenna into another USB port.
Mar 04, 2014 | Logitech Computers & Internet
Trying to connect I Pad to key board through blue tooth
Sometimes Bluetooth devices connect better if they are not too close to each other, so separate them by a couple of feet to see if that helps. If the keyboard is charged and turned on, do you see any lights blinking on the keyboard? there should be some indicator lights if it is working properly. In your Bluetooth settings on the iPad, does your keyboard appear under Devices? If it is listed, click on it to start making the connection. If that doesn't work, click on the arrow to the right and 'Forget this Device'. Turn your pad Bluetooth off then back on and try making the connection again. Often the forgetting process and rediscovering can fix a connection problem. If none of these work, try searching your keyboard brand and model at apple's support discussion for iPad community to see if it is compatible or other people report the same connecting problem. Bluetooth is funky, i've been in an Apple store and could not connect to a Bluetooth device that apple sells in their store, although the store employee could connect his iPad to the same device, we couldn't get mine connected. Good luck!
Dec 15, 2012 | Apple Ipad 3rd Generation 32gb Wifi 4g...
My laser logitech bluetooth mouse won't connect to the laptop again
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Mouse
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth Mouse will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Mar 23, 2010 | Logitech Wireless Access Duo Optical...
Logitech dinovo bluetooth keyboard passkey issue
You entrer your own passkey after hitting the connect button on the KB.
May 28, 2009 | Logitech diNovo Edge Bluetooth® Wireless...
I have an advent laptop and it has no numlock any solutions?? :)
Buy Microsoft bluetooth keyboard 6000... It has two separate parts - one keyboard and one number pad
Apr 18, 2009 | Apple M9034LL/A Keyboard
Connection problem
You will have to have the wireless receiver connected to the laptop. If your laptop has a bluetooth receiver built in, you could get a bluetooth keyboard and mouse. They also make small bluetooth receivers that plug into a USB port.
I hope this helps,
Eric
Jan 19, 2009 | Logitech Cordless Desktop EX110
I cant use my number pad on the right side of my keyboard.
Have you tried pressing the NumLock-key?
It is located right above the key "7" on the numpad/calculator pad.
Dec 17, 2008 | Logitech Cordless Desktop MX3200 Laser...
KEYBOARD QUIT
Problem solved by a representative at Logitech. press (at same time) Alt-ctrl-f12 two times, press reset on receiver, oress connect on back of keyboard then esc.
Dec 02, 2008 | Logitech Cordless Desktop EX110
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
