Ihavw Philibao decoder and does not recieve any channels as it shows message 'no signals'. What ight be the problem and how can i fix it?
Email is bathomoloi@yahoo.com
clusterfx
  • 67 Answers
SOURCE: Searching Signal
you have to upgrade the firmware & key codes and i am assuming your satellite is working and pointing at the right direction
Posted on Feb 27, 2008
CheeseAvengr
  • 57 Answers
SOURCE: dvd decoder
Your video card should have a DVD decoder built into it. If you are actually asking about DVD software however, you can try using Windows Media Player.
Posted on Apr 09, 2008
  • 352 Answers
SOURCE: Want to obtain a Yahoo.com email
These are the folks you need to be talking with:
Customer Care
http://help.yahoo.com/
1-866-562-7219
anaanymous
Posted on Oct 12, 2008
SOURCE: Onkyo TX-SR703 sub problem
What we wound up doing was ensuring that the LPF setting was the same on the receiver as on the sub... that cleared up our problem
Posted on Apr 05, 2009
Ragoney
  • 158 Answers
SOURCE: Almost all of my friends
God bless, try to put the your friends email address on your contact then send them an email for them to reply to, also check your inbox and delete some messages
Posted on Mar 23, 2011
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
I have a panasonic DMR-EZ48V and on the HD channels it says unable to decode HD!what does this mean and how can I get the HD channels to work?thanks
Unable to decode HD is a common banner display message with these combos. It simply means the unit is not engineered to process HD signals. It is a model series limitation; not a fault as such.
This model incorporates a SD (standard definition) integrated digital tuner. It is a major pain in the proverbial not being able to receive HD, and not being able to skip them in any setup menu.
The only thing you could really do here is connect an external HD digital set top box (which would also contain SD channels) directly to the recorder's AV inputs at the rear, and then selecting the appropriate input on the combo unit to suit the source. You could then choose whether to view/record HD or SD via this method, rather than use the unit's built-in tuner.
Works just as well, with minimal error, depending on the signal strength and type of DSTB used.
It's crude, but cheaper, and does not require repairs or messy wiring.
Jun 03, 2011 | Panasonic Televison & Video
My remote scanned all the tv channels (Cable TV, TV, DTV and Cable DTV). The channels that do not show up now are the Cable TV channels. They are there if I type in the channel number but the remote...
U are recieving an using DTV Free AIR broadcasting tv signal wright,get a better antena like a roof or a newly design digital antena for uses.This problems dose not happen to cable or sattellite services,i know this because their broadcasting tv signal frequencies are very strong and very high ranges of a broadcasting signal output for their recieving boxes.
May 09, 2011 | LG 42LH40 LCD TV
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Cannot find freeview/digital on our new TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Televison & Video
Up grading Fortec Star (Lifetime II) reciever.
my fortec star reciever is not up grading through (Action HBS link box) to open Showtime program
Apr 25, 2008 | Fortec Star Lifetime ULTRA
Digital or Analog>
I believe this tv has a built in digital tuner. To verify this, using your remote attempt to change the channel to say 3-1 or 3.1 if you have a digital tuner this is how a digital channel will show up. Also if you go into your menu under channel scan you should see a choice named dtv. And finally on the back you will have a coax connecter named dtv. The latter is not always true. If it does turn out to be standard format tv, you can still purchase a digital set-top box that will decode digital for you. Keep in mind that you must have a good uhf off air signal in your area to recieve digital signals. Good luck.
Feb 20, 2008 | Televison & Video
Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
Nov 24, 2007 | Onkyo TX-SR605 Receiver
No OTA channels
This television has an extremely weak tuner. It is very sensitive to both ghosting (multipath) and weak signal conditions, which cause it's digital decoder to "error out". Coupled with this is the decoder's long set-up time (time to actually begin a decoded video stream after signal is selected)and you find that every time the decoder loses sync it takes several seconds to reestablish normal decoding. The net result is the possiblity that the tuner will be continually restarting and never display anything. An extremely directional antenna may help. Otherwise, find a good external tuner box and use that.
Oct 03, 2007 | JVC HD-52G886 52" Rear Projection HDTV
 Grubhead
Grubhead
