Salter 2001 electronic kitchen scale Logo
A
Anonymous Posted on Jan 10, 2013
How to calibrate Salter 3001
It diplay 204 for 200g weight and 1.036 kg for 1 kg weight.
1helpful
Where can i find replacement parts for Salter 914WHLKR 914 Electronic Baby and Toddler Scale
MY SALTER MODEL 9101 READING DIFFERENT WEIGHT
Could be low battery, could be surface not solid/flat enough, could just be faulty and time for a replacement.
My salter kitchen scale jumps from .99 to 1.01. It will not calibrate at 1.00. I have tried many surfaces. ?
pick .99 ot 1.01 if you use .99 the add ..01 to the weight indicated. use 1.01 the subtract., this is better than buying new scale.
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
https://www.pricescompare.co.uk/q&a/ee-showing-on-screen.html
2answers
I have a Salton 2006. When I replaced the battery and pushed the on button a small icon with + and - above and below it flashed in the upper left corner. What does this mean?
Can you please confirm if this is the product you are refering too?
https://www.pricescompare.co.uk/kitchen-scales/product/salter-aquatronic-platform-scales.html
10helpful
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
23helpful
4answers
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
