Question about Fisher and Paykel DE09 Dryer
How do you remove the front of a fisher and paykel front loading dryer  # DE09-US1 - i want to really clean the lint area  I watched the service guy do it once and it was soooo simple -   but once we have the screws out to lift the top  i cant see what to pop for the front to come lose
  • 145 Answers
Welcome...
You need to look up near the top of the cabinet front, there are screws way up near the top on each side that secure the front panel to the cabinet. Take them out and tip the front forward and then pull up. be careful of the door switch wires.
if you need a comprehensive service manual for that dryer, it can be found here:
http://www.fisherpaykelparts.net/ecart/category.php?category_id=53
Posted on Jan 23, 2009
How do you get the front panel off a fisher paykel dryer to replace the felt seal
my F&P front load dryer would not start - it would hum when I pushed the start button. After trial and error taking the top off, then the front panel with the door I found the lint exhaust was completely blocked. After doing a thorough cleaning of the dryer and putting it back together it worked! (note: DE60 Elba dryer)
Jul 14, 2014 | Fisher and Paykel DE09 Dryer
Bought dryer In October 2007. Now the auto-dry cycle is not doing the job. Clothes are still quite damp when cycle shuts off. The lint bucket is not full and we cleaned out area leading to it along...
You may need to reset the breaker for the heating elements or clean and check the continuity contacts. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 28, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel smartload dryer degxius does not dry cloths. Drum is hot, and lint basket is empty. I have cleaned lint out behind lint basket.
Check and make sure that your exhaust tube and outside vent are not clogged. If they are clean them out and you may have to buy and new lint screen that come with a seal whcih will solve your problem. Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . This forum will further help you through your problem.
Sep 04, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Front load dryer make a horrid squeaking sound as it goes around. Heat's great - it just squeaks!
There are nylon or cloth type guide bushings(bearings) at the front of the drum which may be worn. The drum rides on these to keep it suppurted. You can replace from retailer and or try to lubricate with silicone spray.
Feb 23, 2010 | Fisher and Paykel DE09 Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Where is the reset button on a Fisher & Paykel DE09 dryer?
reset buttons are usually at back of machine and coloured red just push unplug first
Jun 30, 2009 | Fisher and Paykel DE09 Dryer
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Jan 25, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Lint assembly-Fisher and Paykel DEGX1
Pretty easy on the lint assy;
Remove the lint cup;
Find screw (5) in a recess at the bottom of the lint cup area;
This will allow removal of the perforated lint surround, and the 'lint scraper'; Also will expose the moisture sensor (3) hanging off wires at the bottom of the assy;
At the bottom of the surround there is another recessed phillips screw; remove this, then twist the surround (14) counter-clockwise about 1/2" and remove to expose the filter (13).
<img src="http://img50.imageshack.us/img50/9130/outlectductsh4.jpg" alt="FP Dryer Lint parts"/><br/>
Not sure on the reset- I do know the top swivels up after removing the two screw caps and screws at the front of the unit on either side. This exposes the underside of the control panel; there are screws at the back of the control panel also.
Jan 02, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DE09 Dryer Logo
991 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
