Question about Xerox Office Equipment & Supplies
Xerox 550 error 116-321 - Xerox Office Equipment & Supplies
Xerox 550 fault code 045-315 how to solve this error code please give some technics
Error Codes and Support
Web page above states:
Error Description: Drive Logic Fail Solution: 1.Recycle your printer 2.Check all connections to the Engine Control Board 3.Make sure the correct firmware is installed. 4.If the error continues replace, the Engine Control Board (MCU PWB)
Manual for free download at link below:
Fuji Xerox Color 550 Administrator Manual Page 205
Feb 08, 2018 | Xerox Office Equipment & Supplies
Xerox c70 fault code 045-360
you need a service pack to install. the code is a programming mistake/ inability to deal with rotating something see this link and check your software version to see if you need the SP. I guess you do. http://www.support.xerox.com/support/xerox-color-550-560/file-download/enus.html?operatingSystem=winxp&fileLanguage=en&&associatedProduct=XRIP_550_integrated_Fiery&contentId=120034&from=downloads&viewArchived=false
Dec 14, 2017 | Xerox Office Equipment & Supplies
Xerox color 550 has its control panel lights flashing, and printer wont start up
This http://forum.support.xerox.com/t5/Printing/7428-Shutdowns-All-Lights-Flashing/td-p/164967 says do this, carefully.... http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html?objGUID=17471 good luck with that one. sounds a bit like the sort of issue an old hard drive might give you.
Oct 03, 2017 | Xerox Office Equipment & Supplies
Xerox 550 manual
Hi Anonymous,
You need to get hold of your Xerox Concessionaire,
as for a 550 manual you'll be lucky even I don't have one of those.
Regards.
Jul 27, 2014 | Xerox Office Equipment & Supplies
Xerox dc12 error 10-500
Xerox dc 50 error 10-550. How can't I fix it?
Thanks
Sep 14, 2013 | Xerox DocuColor 12 Printer
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
