Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox 52" widescreen tv year of model 2003
When you turn it on, it takes about two minutes to warm up
  • Philips Master
  • 3,459 Answers
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Posted on Jan 26, 2009
Why does my magnavox 52 inch dlp make a fairly loud humming noise for 10 minutes or so after turning the tV on? It gradually get quieter.
It is likely a bad fan that gets quiter as it warms up from use. There are two fans on that TV - one under the bulb housing and one at the left vent hole. They are special fans with three leads - +, - and an RPM indicator (yellow lead typically).
Apr 24, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox 52' hdtv won't turn on when you first
replace your STK ICs they are big black ICs will have part # on them call Mats 1-800-628-1118
Sep 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture getting darker
first thing i would look at is it is probabily dust on the lences and miror, you need to take the screws out all the way arount the screen from the back, then lean the screen out tward you from the front, do this while the tv is on, you will be able to see the dust alot better, take a soft cloth and glass cleaner and clean little miror, and lences
Jan 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
Philips 52" LCD TV
I think what you're talking about is the feature of the TV that auto-adjusts the screen for different pictures. What is does is tries to auto-fill the screen in case there are black bars on top (because of widescreen content) or on the side (regular tv content). It does it mistakenly if it notices too much black anywhere... happens a lot to me when credits are rolling. You can turn this off in your TV settings... I think you just set it to a specific type (widescreen, etc) instead of "auto".
Aug 21, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
