WON"T PRINT Cartriges are new, has been working. Computer says its ready to print. But it won't! I have a Photosmart C7250. have turned it off/on, pulled cartriges to make sure they are snug and unplugged system PLEASE PLEASE PLEASE HELP. Thanks, Suzanne T 757-672-2148
    Problem Solver:
  • 10 Answers
First off all, check if the issue is with the printer itself or is it with the computer.
try making a copy to check if the unit is able to work as a stand alone machine.
if you are able to make copies, then please reply back as in how have you connected your printer to your computer.
I will be able to help you further, I know HP products from past 4 years, I will be able to help you.
Thanks
San
Posted on Jan 21, 2009
  • 45 Answers
Hi Suzanne,
please answer these questions to understand issue better 1)Is it connected with usb or network
2)Are you able to make copies
I don't understand the my printer was working perfect it pass the aliment but I turn off the printer for few weeks and now when I turn on my printer it won't print black it won't pass the
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 31, 2012 | HP Photosmart C6100 All-In-One Printer
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
HP Photosmart C7250 lines in photos
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Jan 09, 2012 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 PRINT JOB REMAINS IN QUEQ THEREFORE WONT PRING
I responded to this on another page turn off printer at power. Turn off or reboot PC then the ques is emptied. Follow my other suggestion for using the right driver and setting up the prnter again in Vista
Jul 28, 2009 | HP Photosmart C7250 All-In-One Thermal...
Error message will not let you print or copy
Please Click Here and follow the instructions to reset your All-in-One.
May 23, 2009 | HP Photosmart C7250 All-In-One Thermal...
Last line getting cut off when printing
go to control panel and click on printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Mar 31, 2009 | HP Photosmart C7250 All-In-One Thermal...
70 people viewed this question
jasbo
jasbo
