8 gb flashdrive by gigabank has malfunctioned. Is there any way I can retreve my data from it? or, repair it?
  • Dan rogers
    Dan rogers May 11, 2010
    how has it malfunctioned? you might have to take this to a data recovery specialist
    President:
  • 8,637 Answers
Yes, you should make sure its plugged into the USB port. Then Open My Computer by double clicking on it.
Look for your Flash Drive and double click on it.
When it opens you can highlight what ever you want to move and right click on one of the highlighted icons and click cut.
Then go back to My Computer and click on "C" drive and go to Documents. Then open the documents and right click and paste . That will move the data.
Hope that helps. Bud
Posted on Jan 22, 2009
Gigabank powers on.....doesnt read onto my laptop.......Dell Inspiron 1525, that of which used to work fine at one time......cant retrieve any of my files....
From your description it sounds like your GigaBank is damaged. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed by an experienced tech remotely over the Internet from a boot cd that you download and the best part is they just ask for donations: http://FreeDataRecovery.us
Jul 29, 2011 | IO Magic Corporation GigaBank (I250HD35)...
My computer wont read my harddrive... I have too much stuff on there that can't be lost
try it on another system if it boots backup your data if it does not only option is data recovery company very expensive
Feb 03, 2011 | IO Magic Corporation GigaBank (I250HD35)...
I plugged my LG USB flashdrive into my laptop last night and laptop said that there was a USB malfunction. I had just used the flashdrive on a desktop. The flashdrive does not light up either. Is the...
Try the flash drive in another computer, if it works then backup your data.
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Nov 22, 2009 | Electronics - Others
I can not copy enything onto the 8gb flashdrive and if copied it cant be deleted again
Do you have a write protect switch on the pen? If so switch it to the open position.
Sep 10, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hard drive shuts off after 10 seconds
There are a variety of things that can malfunction on your external hard drive:
1) The cable
2) The external hard drive casing
3)  The hard drive itself
If you have tried plugging in your hard drive to different computers and are still having the same issue, then there is either a problem with your casing or with the hard drive itself, because you've already switched out cables.
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computerstore, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The GigaBank 320 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period.
For specific warranty and replacement information, go to www.iomagic.com  and click on Support.
Have a nice day,
I/O Magic Technical Support
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Problems with Magic GigaBank 12 GB USB 2.0 Hard Drive?
sounds like bad usb data channels on the drive the far left and far right are powers if im correct the 2 centers are data - and +
(i burned a usb memory stick once with a wrongly wired front usb plug)
Aug 03, 2008 | Magic GigaBank (IUSB12HD10) 12 GB USB 2.0...
Iomagic
Have you looked both in Device Manager and in Disk Management?
Have you tried plugging your external hard drive into another computer?
If it isn't recognized on multiple computers, then you are probably experiencing a hardware failure.
1) The USB cable - Have you tried switching the USB cable?
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on our website.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within the warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
Jun 15, 2008 | IO Magic Corporation GigaBank (I250HD35)...
No detection or read
You could try to download and install FTK - Forensic Tool kit to grab the info. But sadly if the memory won't detect, your looking at having to use expensive software/hardware to grab the info.
Jul 08, 2007 | Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
