Question about HP OfficeJet 7110 All-In-One Thermal Printer
Cannot scan the ! yellow light is flashing.
  • 1 more comment
  • normandlab Jan 26, 2009
    yes i can print
  • Anonymous Mar 01, 2009
    I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
    HP7110 All-In-One
    Thanks
  • santhoshkj
    santhoshkj May 11, 2010
    Please let me know if you can make copies
After turning on the printer, I am getting a message stating "scanner failure" turn off printer. Can't do anything else.
Posted on Jan 26, 2009
Yellow flashing light on screen
It is Progressive Scan mode
if you don't want it then follow this
  • Press the "Menu" button. Turn the control dial and select "M."
  • 2
    Rotate the control dial and select "Prog. Scan." Press the control dial.
  • 3
    Rotate the control dial and select "Off." Press the control dial. The Progressive Scan LED light should go off.
    Performance Chip
May 23, 2012 | Sony Video Cameras
The engine started running rough,and a short time later the Yellow Engine Light came on and shortly after that the yellow light started flashing every time the engine was revving at a high speeds between...
Stop by any good parts store (Autozone, Advance, etc..) and have them do an OBII scan (fault scan) They will pull codes and that will identify what's troubling your truck. Most will do this FREE
Apr 07, 2011 | 2001 Ford Windstar
I have an HP DeskJet F4440. When I press the scan button, the green light flashes then the yellow light but nothing happens.
The yellow flashing light means there is a problem with the feature you're trying to use. If you're trying to scan, it could be that there is not a destination program set up to scan to. You can try using the software to scan instead of the scanner itself to make sure it's not a hardware problem. If you installed the HP software included with the all in one, there should be a troubleshooter you can use to help diagnose the problem as well.
Regards,
Matt
Mar 14, 2011 | HP Deskjet F340 All-In-One Printer
Exhaust sputters engine light flashes car shakes
which engine light? The Check engine light (yellow) or the Red engine light?
Flashing yellow means you are dumping raw fuel into your catalytic converter and will ruin the $800 cat very quick. It means you have cylinders not firing. Go to Autozone and get the fault codes to see what the cause is.
Aug 11, 2010 | 2001 Ford Focus
Yellow check engine light is on - is it OK to
as long as the light is not flashing, you should be good to go. you can also have a parts store scan the system. most parts store will do this at no cost. doing this would make sure nothing serious is going on.
Jun 20, 2010 | 2006 Volkswagen Jetta
My indoor photos all have a greeninsh yellow effect
That's caused by lighting. More specifically by the type of lighting in use there. Every different type of light puts out a certain color range, some pink, some green, some yellow, some bluish.
How do you fix it?
1. use flash. Flash puts out a bluish light color balanced for daylight. Most film available today is color balanced for daylight. Problem here is that on camera flashes are weak and only reach about 10 feet. The rest of the picture will be greenish yellow. More powerful flashes extend that 10 feet based on the power they have, and may provide enough coverage. The reach of the flash is also determined by the film ASA.
2. use a filter on the lens. Get an FLD (flourescent-daylight) filter.
3. Scan the negs to digital and correct with Photoshop or another photo editing program.
Jan 24, 2010 | Fuji Photography
My engine light started blinking and there was a hesitation in the engine when yo pushed on the gas.
if it's the yellow check engine light flashing, it means you have a serious rich running engine that will destroy your $200 catalytic converters very quickly. do not drive with a flashing light.
run computer scan for failure codes and replace bad sensor. auto zone will scan for free. Don't drive too far though.
Aug 13, 2009 | 2001 Ford Windstar
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
HP OfficeJet 7110 All-In-One Thermal Printer Logo
47 people viewed this question
Ben Johnson
