Question about Brother IntelliFAX 1270E Plain Paper Fax
2 inch vertical solid band on right side when making a copy
Brothers Intellifax 1270 Plain Paper Facsimile
Also when I send a fax, the recieved fax has the same black band on the right side.
  • Anonymous Mar 20, 2014
    scannner
  • Anonymous Mar 27, 2014
    solid black page
    Novelist:
  • Brother Expert
  • 297 Answers
There is probably dirt or ink on the scanner glass, this would affect both copying and sending faxes.
Here is a link to the manual and a description on page 74 showing how to clean the glass.
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
Posted on Jan 22, 2009
I can send a fax but it will not recieve a fax Intellifax 770 Brothers Home/Office plaine paper fasmile.
Have your phone line check for noise. Level may be to high and the machine can not hear over the level,it has to here the tones from the other fax to hand shake. Good luck
Jul 21, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Every time I fax or copy a perfect sheet of paper both the fax received and the copy have a 2 inch wide solid black line on the right. How do I fix the machine?
Have you tried replacing the ribbon cartridge? If that doesn't resolve the problem, then there is a fault with the thermal imaging head. You did say both Recieved faxes and copies, correct? If faxes you send out are clear, then the above mentioned would be correct. Let me know, please.
Oct 12, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
When I send a fax, the recipients report a black band appears covering 3/4" in one margin
Open the front cover and clean the scanner glass - there must be some alien substance like dried up correction fluid or ink on it that causing lines to appear on the recieving side.
Oct 02, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Brother Intellifax 1270 Plain Paper Facsimile
I called customer service and they helped me. It works now. Thank you for your help.
Jul 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Brother 1270
One of 2 things going on here.
If it is in the same spot all the time on sent faxes.
There could be some contaminant on the scanner glass, Some toner, white out or a piece of paper blocking it.
With as wide as it is, that is not likely.
I would think with it being that wide, once section of that scanner CCD assembly has failed. That would need replaced and probably pretty costly.
As was asked above. Does this problem occur in copy mode and does it repeat when you print out a report.
Mar 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Changing Cartridge
sounds like its in backwards or upside down, did you put a whole new cart in it or a refill roll?
Jan 08, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Recieve but not send
Is your handset plugged in the right hole. Customers occasionally plug the handset in the hole marked ext.
Dec 07, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
236 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
