Question about Vizio L37 Television
My vizio looks like its in xray mode
White screen and people and picture looks like an xray machine
3 Suggested Answers
dave1645
  • 834 Answers
SOURCE: the screen is just white
t-con board has failed very hard to get parts try shop jimmy .com
Posted on Sep 18, 2009
budmrtn
  • 11361 Answers
SOURCE: Seeing occasional white lines in picture in Vizio
It can be the LCD panel, T-CON board, or main baord, very difficult to narrow down since you will need the service manual to look at all the signals with the scope.
I would try reseating the ribbon cables between the panel and the T-CON board first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Apr 19, 2011
I have a Vizio model M651d-A2r that will not turn on and is unresponsive. As soon as I plug the tv in, the screen displays a horizontal line, a slope line, and a vertical strip of white (see picture).
it is still under warranty ?
One Year Parts & Labor; Free Lifetime Technical Support
ring tech support first
http://vizhdtv.com/contacting-vizio/
first sight of picture says cracked in behind screen
unresponsive is worse
if it doesnt show a picture at any time
looks replace a circuit board or the flat panel
cost of used/ referbished units
http://www.amazon.com/VIZIO-M651d-A2R-65-Inch-1080p-Smart/dp/B00CBQNB7K
May 18, 2016 | Vizio Televison & Video
Vizio picture
It looks like your picture is zoomed, that control should be on your remote. Or change your picture ratio. Tints are all messed up. I would bring everything back down to black and white and start adjusting back up. To do this you have to be in picture mode custom (your pic shows your in standard mode). Everything else is preset for you. Go into all your settings and make adjustments. I also own a Vizio. It took me several attempts to adjust the picture to my liking.
Mar 17, 2014 | Televison & Video
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
My pictures look like x rays
XRays ARE black! So if you changed your color to black, everything will be in black-and-white. No damage has been done - just change back to 'default colors' Good luck!
Jan 16, 2014 | Computers & Internet
Cannot adjust color looks like xray
Should have picture options in the menu,,check for advanced options for a alignment options,,,check the manual,,and go to official website of your products under support /register for help,good luck
Dec 23, 2011 | RCA Televison & Video
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
Screen is stretching on each end. Vizio 32 inch. The picture is stretched on each end. The picture looks real weird and it almost makes you dizzy when you look at it.
Sounds like the display is in a mode which is sometimes called "Horizon", where they seek to fill the entire 16:9 screen with an image which is originally 4:3 by leaving the center of the image mostly alone and stretching the ends out horizontally. If your remote control has an "Aspect" button you might try pushing that a few times to cycle through the various settings.
Oct 10, 2009 | Vizio Televison & Video
Screen does not show picture, distorted image
If you go to 1800customersupport.com it has some good info. Alco Electronics is the maker.
Oct 04, 2008 | TruTech PVS12701 Portable DVD Player
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Picture problem
i have vizio that turn on, but no picture, and the invarter light is on and it won`t turn off.
Oct 20, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio L37 Television Logo
76 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
