Question about 1A Auto Parts 1995 Pontiac Grand Prix SE GM Style Black Lug Nut Cap Set of 5 fo
High Rpm's and wont go down and car over heating,
We changed out the radiator, thermostate water pump and bled the lines and the car still overheats,, also the RPM idles at 2-3000 rpms and wont go down then it over heats
  • Kevin Sharp Jan 12, 2013
     we  done everything  even  removed the  thermostat  and it  stillover heating one  fan is  runnin g one isnt we have  removed the  fan  motor and replaced and  the  water pump,  and the  radiator the  car still heating up no   vacuum leaks that we  can  find  and no  loss of antifreeze,  car used to  run 180-190 now it   wont  run  10 minutes without  overheating  and  the  rpm's  run  between  2000 and  3000 and   wont   go  down  usually run  jsut  around  or  under  1000  rpm  any odeas on what  causing  thie  the only thing we  did  first was replace the radiator, it  had a huge  crack in it,,  and  that w aht caused all this too  happen,,  any idea;s
  • 1A Auto Parts Master
  • 9,587 Answers
Look at the thermostat by pass hose of it's nor blocked then look at a blown head gasket
Posted on Jan 17, 2014
Changed thermostate but heater wont get hot and engine temp goes way high
This will happen if the system is not completely bled of all air. If you are sure there is no air in the system you may have a defective water pump impellar or possible headgasket issue
Jan 05, 2016 | 2001 Infiniti QX4
2002 aztek no heat at low rpm changed thermostat and water pump has heat at 2000 plus rpm
Defective thermostat probaly staying open, Or a blockage in the cooling system , Flush out the whole ststem, End don,t have the front of the vehicle raise up,
Nov 28, 2012 | 2001 Pontiac Aztek
I had flush my f150 put new water pump and thromastat still over heats?
Okay so flushed it, changed the pump and the thermostat. Check the levels of fluid in there, make sure it's correct and that you bled the air out if you need to on your vehicle(refer to manual) It's not uncommon for a new thermostat or waterpump to be faulty. It's also possible that you have a clog somewhere in your radiator or the heat lines going into the vehicle. Did you flush it yourself? Are you sure the flush was done correctly?
Jul 30, 2011 | 1998 Ford F150 Regular Cab
Why does my 1997 oldsmobile cutlass supreme keep over heating,replaced water pump, thermostate,fan relays.what else could it be.also did radiator cap.
coolant temp sensor for the computer, did you bleed the air out of the system as well that is a big thing on those to be sure theyre bled out right.
Jul 24, 2010 | 1997 Oldsmobile Cutlass Supreme
The car wont stop over heating ive changed the water pump timmingbelt thermostate
Have you checked to see if the fan goes on for the radiator?
Jul 08, 2010 | 2000 Dodge Neon
My car is heating. there is no leaks. the radiator fan keeps going even when there is water in the tank. my car is a ford falcon, XR6.
Sounds like it could be the thermostate, or the water pump? Or the radiator stopped up. Can you see water working and moving around in the radiator with the cap off and motor running? You can check thermostat by placing it in water on stove and turn heat on high. It should open up right before the water starts to boil. but it is only ten fifteen dollarsl. May as well change it anyway.
May 11, 2010 | Ford GT Cars & Trucks
Over heating
The water pump has what's called a 'weeping hole' built into it. If the pump is bad You'll se water coming out of the hole. When was the last time you flushed the radiator? It may be your radiator cap is bad, they should be changed once a year & the radiator flushed. You can also test ur thermostate. take out ur thermostate & put it in a pot of water so that the water covers the thermostate. Then put a cooking thermometer in the pot to & heat the water til it says 195. u should see the car thermostate begin to open. if it don't it's bad & needs replacing.
Sep 22, 2009 | 1995 Volvo 850
After a short driver water comes out expansion tank
CHECK WATER LEVEL CHECK OIL LEVEL IF NO WATER FILL UP AND IF WATER DISSAPERS OR TURNS MILKY YOU HAVE A HEAD GASKET PROB CHECK WHILE RUNNING BUT DONT GET TOO HOT
Jul 29, 2009 | 1995 Mitsubishi Montero
Changed thermostate still overheating
what about the water pump? is the water circulating
is the electric fan working? check all these things outlook in the radiator see if the water is circulating feel the top hose is it cold or hot when the engine is runing
Jan 01, 2009 | 2002 Pontiac Grand Prix
Over heating
remove the water pump first, bmw's often fail on their plastic impellor, if thats is the fault an easy and relatively cheap repair.
good luck lee
Aug 15, 2008 | 1996 BMW 318
1A Auto Parts 1995 Pontiac Grand Prix SE GM Style Black Lug Nut Cap Set of 5 fo Logo
51 people viewed this question
Top 1A Auto Parts Tools & Hardware - Others Experts
Pete Bruk
Lawrence Oravetz
William Alequin
Are you a 1A Auto Parts Tool and Hardware - Other Expert? Answer questions, earn points and help others
