I have Philips AJ301D DOCKINGENTERTAINMENT SYSTEM. We turned it of before going on holidays when we returned we are unable to reset the time function & the radio also will not play however we can
We turned the unit off when we went on holidays. When we returned we turned it on but are unable to reset the time function and the radio no longer works. However we can play the ipod
    Genius:
  • 1,669 Answers
Here are a couple of websites that should help you:
download.p4c.philips.com/files/a/aj301d_79/aj301d_79_dfu_eng.pdf
www.manualslib.com/manual/175974/Philips-Aj301d-79-User-Manual.html
Posted on Jan 11, 2013
Workday function in excel formulas
The WorkDay Function returns a number that's the serial date that is the indicated number of working days from a given date (the starting date). Working days EXCLUDE weekends and any dates identified as holidays. Use WORKDAY to exclude weekends or holidays when you calculate invoice due dates, expected delivery times, or the number of days of work performed.
The Syntax is:
=WORKDAY(start_date,days,holidays)
where:
- start_date is in Date format (and can be a calculated value);
- days is a number of elapsed days after start_date (can be calculated, can be negative to indicate a date BEFORE start_date);
- holidays is an array of holidays you can specify if desired.
May 01, 2014 | Microsoft Excel for PC
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Return key acts as cap lock key
Go into System Preferences and select Keyboard & Mouse
Under Keyboard click on Change Keyboard Type... button
• Follow the basic steps to reset your Keyboard via the screen prompts.
Once you have done that select the Keyboard Shortcuts tab.
• Click the Restore Defaults button.
Now test your keyboard's return key. If this still does not resolve the Return key not functioning in the normal return key functionality,
Click Show All and go to the Universal Access pane in System Preferences and under Keyboard tab, make sure the Sticky Keys radio button is turned off.
Try these steps and let me know if there is any change.
-Mactechtrainer
Jan 26, 2010 | Apple M9034LL/A Keyboard
Philips gogear 8g is frozen.
My mp3 player (philips) power come on then freezes up @ go gear.
Jul 17, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips Laserfax 725 SERVICE [2] ERROR CODE
Service 2 relates to the Fuser unit. It will have to be replaced by an engineer.
Apr 17, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
My Philips 19pfl3403d/f7 wont turn on without unplugging first.
just call philips and they will send you a new t.v.! it isn't a recall, that would be bad publicity!! i spoke with a philips representative yesterday concerning my 'possessed' television. a gentlemen informed me that philips has a 'rapid replacement program' for the described 'possessed' t.v. set. simply provide model and serial numbers, time and place of purchase, then provide street address for fed-ex delivery. approximate time of arrival is 10-15 days. you are directed to package and return the old set to nearest fed-ex pick up site. i am super excited that i took the time to call philips support. i think that i spent a total of 10 minutes on the telephone; it was time well spent. oh yea, here's the number!
Speak with a Philips representative
1-888-744-5477 Monday - Saturday 8:00 am - 11:00 pm EST Sunday 9:00 am - 6:00 pm EST Excluding major holidays
Mar 31, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Total Factory default of Philips 37pfl9703
hold down menu button on set until it does a factory reset
Dec 07, 2008 | Philips 32PF9966 32 in. HD-Ready LCD...
Help!!!!! My philips SA3125/02 isnt working!
Reset will NOT delete all your music, but the permanent fix that you need to prevent this from happening again will delete all the songs. Reset, and see if it works. But it might freeze up on you during vacation. You will have to keep pushing reset until you get home and have more time for the permanent fix.
Jun 10, 2008 | Philips SA3125\02 MP3 Player
Unable to lock/unlock doors with key or remote
In answer to your question nothing had been replaced or repaired prior to the problem.
Batteries in all the remotes or the car have been renewed. Problem still exists.
Removal and replacement of the fuse 25 resetting the ignition module. Starting the engine and moving the car to a different location the locking system operated normally but on returning to my home the system failed.
My wife returned home later and her car a different make and model would not lock.
I have since turned off my broadband wireless network system and holding the lock button for approx 15 seconds the lock operated.
I will post findings after further trails
May 29, 2008 | 2001 Volvo S80
k24674
jasbo
jasbo
