Question about Bell & Gossett 1BL068LF PL-55B Booster Pump, Permanently Lubricated 2/5HP, 1 Phase, 115 Volts, Bronze , 40 GPM 15
How to remove and replace the impeller on a Bell & Gossett PL-55B pump.
The impeller has come loose from the hub.
    Genius:
  • 1,669 Answers
The following websites are parts suppliers for Bell and Gossett pumps and should be able to tell you the exact instructions especially if you buy the impeller from them:
www.statesupply.com/pumps-for-heating/bell-and-gossett/series-pl-pumps-and-...
www.nationalpumpandsupply.com/bell-gossett-pl-pump-pl-55-2-5-hp-motor-1bl03
Posted on Jan 11, 2013
No hot water from bell & gossett autocirc hot water pump. what is the cause
the pump itself doesn't make any hot water it merely circulates it around your house to the sink outlets , this pump has a unique feature as it auto senses the temp of water and starts itself when it dips low , if you don't get any hot water even if you wait 4 it a moment then id have a service tech ck your water heating equipment , as it seems its not working
Mar 07, 2015 | Bell & Gossett e3-4_/BDPRC Autocirc
Bell & gossett series 100 squeaks when it stops
Sounds like it is not getting oil. The bearing oil fill cover can be removed by lifting outer plate with a screwdriver. Ck that the wicks are covered with oil , if not oil them. Put 3 drops in motor oil fill tubes. If still squealing, replace.
Apr 27, 2014 | Bell & Gossett 106189 1/12 HP Series 100...
What would cause a circulator failure?
I am going to assume the circulator pump is on a hot water circulation loop. Turning the water back on could have stirred up the sediment that has collected in the bottom of the water heater. This could clog up and possibly ruin the impeller. Running for an extended period without circulating water can overheat and damage the pump also. It is a good idea to hook a hose to the water heater drain and flush out the sediment periodically. Hope this helps.
Jan 18, 2014 | Bell & Gossett 103252LF NBF-22 Circulator...
Boiler is hot but circular pump is cold
It sounds like the pump is not operating properly. I would guess convection is causing some of the rooms to heat or you have another pump. Check if you have power at the pump, if so it is bad. If not then check the thermostat and relay, one of those probably failed.
Dec 16, 2013 | Bell & Gossett 103350 NRF-33 Red Fox...
Noisy water pump
Replace the bearings...they are the noisy part
Apr 03, 2013 | Bell & Gossett 103258LF NBF-9U/LW...
Water not draining from machine . cleaned out pump but still not working.
Believing the pump to be operational, there is a possibility that the impeller within the pumb is broken or loose on the shaft. Eventho the pump motor is running the water is not being "moved" through the pump because of the bad impellers.
Nov 04, 2010 | Hotpoint Washing Machines
How do you pressurize a hot water boiler?
If the pumps run, but do not circulate water
make certain that all the air is out of the system
bleed air from coin vents and open caps on auto vents
If there are not sufficent means of air elimination, there are some other options, such as using an auxillary pump to force the air out
Oct 15, 2009 | Heating & Cooling
I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Aug 24, 2009 | Little Giant Submersible Fountain Pump
Bell & Gossett 1BL068LF PL-55B Booster Pump, Permanently Lubricated 2/5HP, 1 Phase, 115 Volts, Bronze , 40 GPM 15 Logo
163 people viewed this question
Top Bell & Gossett Plumbing Experts
Paul Carew
Tom Chichester
Are you a Bell & Gossett Plumbing Expert? Answer questions, earn points and help others
