Question about Samsung 300E5A-A03 laptop
Cannot fix cd into cd drive in laptop series 300E5 as middle part of cd drive is larger than the hole in the cd can anyone help
We cannot fix a movie cd into the cd drive on the new lap top as the middle part in the cd drive is larger than the hole in the cd -- can you help
  • Samsung Master
  • 2,072 Answers
It's suppose to be that way. If you look closely at the CD tray there are tiny spring loaded notches. Just push the cd down and it will snap on the the center. This is designed to hold the disc in place.
Posted on Jan 11, 2013
2 Suggested Answers
  • 262 Answers
SOURCE: samsaug v25
well, i have had the same promblem,hate to say it but sometimes the type you bought isn't compatable with your laptop ...mite consider saleing that one and asking samsung what kind of cdrw's will work with that laptop
Posted on Jan 05, 2009
My DVD player on my Toshiba U305 series laptop won't play. It froze last night in the middle of a movie and wouldn't let me do anything. Then, the disc ho;der wouldn't open. I finally got it open and still...
Unplug from the mains and then remove the battery. Leave for ten minutes then put the battery back on. If it still does not work then it has had it. turn it over so you can access the underside and locate the one screw that holds the drive to the chassis. remove the screw and the drive will slide out. Take the drive to a computer shop and buy a replacement. refit in reverse and all will be well.
Apr 23, 2011 | Toshiba Satellite U305-S2804 Laptop
Tip
HOW TO FIX EVERY LAPTOP PROBLEM USING FULL VIDEO GUIDE SERIES
Hi Every laptop owner or user, carefully selected and packed guides here are how to guides on fixing every laptop problem without having to bore a hole in your pocket any longer. The guides covered and illustrated are guides on:
How to replace a motherboard and the rest of the following guides include
  • How to replace an LCD Screen
  • What to do when the laptop keeps shutting down
  • How to fix DC power jacks
  • The crucial difference between a bad screen and a bad inverter board
  • How to replace hinges
  • Where I buy all my parts
  • The best way to go about taking a laptop apart
  • How to solder
  • The art of fixing AC adapters
  • How to handle a laptop that has had liquid spilled in it
  • what to do when a laptop overheats
  • how to replace CD/DVD drives, RAM, processors, hard Drives and wireless cards
  • and much, much more!!
Watch this video. This is just a Med-Def sample of what you'll be getting in this collection!
Or watch the full 960x540 Hi-Def video here. (You'll need Quicktime installed to stream the HD video)
DOWNLOAD PORT FOR FULL LENGTH OF VIDEO HERE>>> AC_FL_RunContent( 'codebase','http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0','width','640','height','400','src','gatewaylaptop','quality','high','pluginspage','http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash','movie','gatewaylaptop' ); //end AC code
on May 30, 2010 | Computers & Internet
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
How do you remove the cd/dvd drive from the asus pro50 series notebook?
I'm not sure about your charger problem. To remove the charger just pull out the plug by the thicker part at the plug (not by the thinner wire).
Look for a small hole near the CD door. Using a large straightened paper clip push in while gentle pulling on the drive. There is also a small hole which releases the CD tray. If the drive does not have this hole look on the bottom of the laptop and locate the small screw retaining the drive. When reinstalling do it slowly, keeping the drive very straight as there are several connections it goes into on the laptop.
Apr 14, 2011 | ASUS PRO 50 Series Laptop Charger...
I cannot get my CD out of my Dell Studio. Where is the eject button?
In an emergency you can use an unbent paperclip (or anything similar) in the tiny hole on the front of the drive, that will release the catch and open the drive. You can do this with the notebook on or off.
Oct 29, 2010 | Dell Studio 15 Laptop
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Lines on screen of HP Pavilion zd7360us
Hello, please report your story at hpverticalline.com so your computer model may be added to any future legal suits.
Jan 15, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Samsung 300E5A-A03 laptop Logo
29 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
