Question about Invacare Health & Beauty
Will a TDX controller work on FDX chair?
GTRAC-PMA90 is on the FDX, and is CTRL INHIBITED, will not reset DKPMC-28 MK6 90 w/ACC is on the TDX SP, i'm bidding on this to replace the former
  • tchrey Jan 13, 2013
    I have gone through the entire system checking all connections. I have a programmer and have reset all faults and programs. Still won't budge.
3 Suggested Answers
  • 692 Answers
SOURCE: The joystick on my TDX wont make the chair move
count the number of flashes of the wrench and it will tell you what the error is. ie 4 falshes right motor Your owners manual should have the flash codes in it and will explain the error you are having Hope this helps
Posted on Feb 27, 2011
SOURCE: TDX SP; the screen reported
Seems the Control Panel is not connected properly on the unit or may have gone lose check the control panel cable connection on the unit.
Make sure that when check the connection it is turned OFF and not plugged in or charging to avoid any short or shock.
See below for info on how to check the control panel connection,
See picture below to check the controller connection form the battery.
If the issues till exist then probably the controller program is corrupted or may need reprogramming on the unit.
The reprogramming can only be done by a service technician of Invacare for the reprogramming of the controller if you still have the Manual supplied with the wheel chair it should have the info ther and number to call, if ever the connection is not the issue.
I hope this helps.
Have a nice day,
mvincentc
Posted on Aug 04, 2011
My tdxsp wheelchair will not power off
This should help you: Invacare,s TDX - SP power wheelchair - YouTube
Sep 26, 2015 | Health & Beauty
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
When i turn on my chair it reads controller and does nothing but flash controller
If this is when the charger is plugged into the chair, the chair goes into inhibited mode so you cant drive away towing the charger with you. A safety feature.
Jun 06, 2015 | Invacare Invacre Battery Charger...
Where is the reset button on this wheelchair
It sounds like the joystick has defaulted back to some other programming. A Reset Switch is a switch that plugs into one of the Mono ports on the joystick. You will need to either have the chair reprogrammed by a service/dealer of power chairs or purchase a reset switch (sometimes called a momentary switch) to plug in to the joystick. The Reset switch has a long wire with the proper plug on it. There are many different types and prices for one of those so getting the chair reprogrammed may be easier.
Feb 07, 2015 | Invacare Health & Beauty
My Invacare TDX SP has died on me and someone told me of a trip switch on the batteries..Anyone know where this switch is as all I can see are bolts and metal?
http://www.invacare.com/doc_files/1143190.pdf
Owners manual for TDX SP link above.
First check if you have power present at the charging port. If you have power (24 volts) then the batteries and wiring are not the issue. If you don't then check the battery post fuses. These are "L" shaped brackets with a white square fuse held on the positive post with a through bolt and nut. On older chairs these are known to become loose and or blow just when you need power or stop suddenly.
Also check the big Anderson connectors at the power point at the end of the battery box. Check for solid connections. If there is 24 volts here to the control box, next check the controller connector.
If there is +24 at the controller connector but 0 at the joystick charger port you have big issues. Either the traces connectors in the controller are fried or your joystick has major issues.
Mar 06, 2014 | Invacare Supply Group Health & Beauty
What is the remote on a tdx chair
The "remote" refers to a joystick remotely located away from the controller. In comparison, an integral joystick is where the joystick and controller are integrated into one part.
Nov 03, 2013 | Health & Beauty
Troubleshooting an invacare tdx sp electric wheelchair
Behind the drive wheels is a selenoid that has a flip up for "PUSH" and flip down for "DRIVE", make sure they are both in "DRIVE". That's what worked for me.
Oct 13, 2012 | Invacare Health & Beauty
Invacare TDX SR
I live in Sonora, Ca. and am looking for a place to get my TDX SP chair fixed. It need some new leg rest that don't kill my legs 5 mins after I set down. Something on the back of my chair is broken where it attaches to my back plate. and a few more things. I tried a place in Modesto, CA and they stink!!! Over charged me, asked for the money upfront before my inc. had a chance to make good on it, and then it took them 6 full months to refund my money that was over the copay I have to pay with my blue cross inc. Please tell me a place I can get some work done, my chair cost over $6,000 and It has served me will, but I need to take care of it.
Jan 23, 2012 | Invacare Pronto M51 Power Wheelchair
The joystick on my TDX wont make the chair move and a key insignia flashes. Battery is fully charged and the other controls ( chair tilt and footplate lifts all work OK. What can the possible problems be...
Feb 27, 2011 | Invacare Health & Beauty
Message on storm model tdx 3 joystick is ''E 15 M1 power stage faulty''
J I am not familiar enough with the TDX to give you an answer but you can contact Invacare Tech support @ 1-800-333-6900 ask for chair tech suport and explain your problem Hope this helps
Sep 27, 2010 | Invacare Health & Beauty
Health & Beauty Logo
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
