Question about Air Tools & Compressors
Rockworth nailer and stapler model RW-BNS - Air Tools & Compressors
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I need a manual for my 18 ga combination nailer/stapler kit
What you can do is go to the Sears.com website and under tools it will lead you to Sears Parts Direct and (bottom of page) when you get there there is a block for manuals type in the model number and you can view it online or get one. Hope this helps Dave
Posted on Dec 21, 2008
  • 142 Answers
SOURCE: My brad nailer shoots staples without any problem
the only suggestion i have is that you may have a feed problem, so i would clean and lube the track the nails run on
Posted on Mar 27, 2010
  • 1388 Answers
SOURCE: does the campbell hausfeld model
Sb504000 works just fine with pressure range from 60 to 120 psi depending on material. Any small compressor will work great. Using the gun at max pressure will shorten the life of the gun. Best practice is to set pressure to just under 100psi for most work and increase pressure when nailing hard wood. Using at max pressure will strain the driver and the lower part of gun (screws that hold nose to body). Some hard woods will bend an 18 gauge nail. Good luck with your gun and have fun with your projects.
Posted on Aug 11, 2011
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
PDX50C 3-in-1 Flooring Air Nailer and Stapler with Fiber
Check the seals so see if they are there/ in the correct postition. If they are, get new ones, mebbe oil them.
Sep 16, 2013 | Freeman Tools & Nailers PDX50C 3-in-1...
I have a craftsman 18 gauge nailer/stapler the only # I see is 351.184540 when connected yo air supply it only hisses no firing. Took off depth setter on rear of gun inside it appeared to b a diaphragm and...
Model 351184540 CRAFTSMAN COMBINATION NAILER STAPLER Parts
You can price parts and decide if it is worth it, is the gun old, used much etc. If you don't use it much HF sells inexpensive ones. If you use it more often buy a better name brand at HD, Amazon E bay.
I have a combo nailer/stapler and i only use it for staples. The combo will put a bite mark on your wood. I use a nailer that doesn't leave marks so cleanup before finishing is much easier.
Oct 29, 2017 | Air Tools & Compressors
No instructions for campbell/hausfeld 2-in-1 nailer/stapler. need to load stamles and where do I put oil?
Hi Barbara,
Can you please check if there is a model number on the nailer.
I need this to search for a manual from the manufacturers database. The model number probably starts with "PL"
Nov 04, 2011 | Campbell Hausfeld 1 14 2 In 1 Brad Nailer...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
What is the correct way to place the nails into the gun? This gun uses both cleats and staples. I am using cleats but it does not seem to be working. I may be putting the cleats in wrong.
If you have a Bostitch MIII FN it is only for cleats. Bostitch doesn't make a universal nailer that takes staples and cleats. The MIIIFN is the "floor nailer" and the Model MIIIFS is the "floor stapler"
Maybe check exactly what model you have and ensure you are not trying to put cleats into a stapler.
Oct 17, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
CAN'T LOAD STAPLER Hava a power master stapler model apm125n but can;t re load staples as have losr instructions
You should just be able to pull the cartriage slide at the back of the loader. it sometimes sticks, give it a good yank/
Aug 08, 2009 | NRS Paslode 501000 Powermaster Plus...
Dec 20, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
71 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
