Question about Emerson Im90 Portable Ice Maker 3 Setting Machine
Need to change the fan - Emerson Im90 Portable Ice Maker 3 Setting Machine
    Genius:
  • 1,669 Answers
If you need to get a motor to replace the one in it please go to:
www.repairclinic.com/Ice-Machine-Motor-Parts
or to find out how to do it:
forum.appliancepartspros.com/refrigerator-freezer-repair/20382-ice-maker-fa...
Posted on Jan 11, 2013
Remote will not start fan battery has been changed
There is more than one battery that needs to be changed. There's another one in the receiver, inside the fan's cowling, on top of the fan. Also, make sure the wall switch is ON, after you change the second battery.
Hope this helped you. Please let me know. Thanks.
Jun 23, 2011 | Hunter Fan 21894 Heater
Need to know where the fuse is for the fan by the radiator. I know where the fuse box is at because mercury sable has 2 boxes. Which one contains the fan fuse. My fan is not working and been replaced and...
You have a relay there are 2 speeds low speed and high speed this is controled by a cooling fan module if you changed fan and it does not work then you will need to check the fan module, first the relay its in the engine fuse junction box High speed is marked on the relay C1056 and low marked C1058, here is what you can do go to the high spped relay open thhe cover and expose the relay with key on collapse the relay does the fan come on? if it doesnt replace the fan module if it does you will still have to replace the fan module here is the location is at the radiator on the front (may be under shroud)
Jun 08, 2011 | 2003 Mercury Sable
I need to find an CPU fans/Heatsink Part for my Compaq Presario Laptop Does any body know where to get tham at and cheap to??
you no need to change the heatsink only need to change the fan and visit your nearest whole seller and tell me to give you a one fan for your laptop. dont change the heatsink ok . just clean it well. may i know why you are chaning your fan? you having a slow speed of fan? just open the steaker of fan and you can see the hole there just put the few drops of oil and then try.
Apr 19, 2011 | Compaq Computers & Internet
I have 4 fans all on same code how do i change
You need to change the dip switches to different codes. Most likely it's a 1-4 small switches. Factory default is usually all on. Just change each fan to different positions and make sure you do the same with the matching remotes. The remotes must match the corresponding fans.
May 30, 2010 | Hunter Ceiling Fan Light Remote Control
Can i hang a ceiling fan on a 15 lb bracket box for a light fixture or do i need to change out the bracket box?
Absolutely change out to a bracket and box rated for a ceiling fan. Even if your fan does not exceed 15 lbs a non fan rated bracket and box is not made to endure the vibrations and other motions created by a ceiling fan
Sep 06, 2009 | Hunter 52" Ceiling Fan With Light And...
I just changed the radiator of my 2001 Maxima and the fan stopped working. It was working fine before I changed it. We checked the fuse, thermostat, wires and they all good. the mechanic told me that the...
The ECU drives a relay which in turn drives the fan. Trace the fan wiring back to the relay and check the plug connection. Does the fan turn freely by hand? If not, replace it. The fan needs a solid ground connection as well as power from the relay.
Aug 04, 2009 | 1988 Nissan Maxima
Antec fans connected to akasa fan controller, Speed doesn't change
Sounds like a problem with your fan controller. The controller is simply controlling the voltage applied to the fan to adjust the speed. Have you tried a fan without a speed control built in?
May 09, 2009 | Akasa Fan Speed Control Fan Controllers
Need website to register hampton bay ceiling fan? Please help.
You can change the entire appearance of your fan by simply changing the ceiling fan shades. If your ceiling fan is outdated, you can change its look with new shades and even new blades, no need to take it down.
Replacing the ceiling fan shades is an affordable and practical alternative to purchasing a new ceiling fan. The amount of work in removing the old fan and installing the new one is enough to have you considering replacements of shades and blades as the best answer.
The Many Styles of Ceiling Fan Shades
Ceiling fan shades come in a variety of shape and size. With the huge selection, you are sure to find one that is right for you and your décor. In addition to the different sizes and styles, the materials can come in various styles, such as:
• Smoked Glass
• Etched Glass
• Beveled Cut
• Smooth Surfaced
• Ridged or Bumped Glass
There are an endless combination to the ceiling fan shades styles and materials.
Apr 10, 2009 | Garden
Hampton Bay 46056 fan
I have three Hampton Bay Ceiling fans with remotes for eight years. I doesn't help when a neighbor buys the same make and model. So, I had to come up with a different code for mine. I had to change the code for the remote and match it with the code in the fan. To change the code in the fan, that depends on the type of fan you have, some you would need to look on top of the fan and use a skinny stick to change the code, other's you would need to take the light fixture down to get to the controller box to change the code. I have both types, this is how know. PS. if ever, which will happen, if the fan doesn't respond to the remote then you would need to replace the controller inside the fan. Here's the warrenty no. 800.749.3267 for replacement.
Dec 24, 2007 | Hampton Bay 46056 Callaway II Ceiling Fan
Emerson Im90 Portable Ice Maker 3 Setting Machine Logo
83 people viewed this question
Top Emerson Refrigerators Experts
John Tripp
John Tripp
mike cooper
Johnny 1000
Level 1 Expert
Are you an Emerson Refrigerator Expert? Answer questions, earn points and help others
