Question about Westinghouse LTV-19W3 19 in. LCD Television
Takes tv 10 minutes to power on
After tv powers on it works fine!
  • Westinghouse Master
  • 933 Answers
Check the capacitors in the power supply
Posted on Jan 11, 2013
Converter only works properly after it has been left on for about 20 minutes
In my years as an Electronic Technician I have had two simular situtions happen to me. Both were in TV's but the results was the same, they had to 'warm up'. Then they played fine until they cooled off. I finally discovered that in the power supply I had a ceramic resistor that should have been about 2 ohm had changed to Mega ohm and was not letting power through fast enough to start quickly. Once it got the caps built up it worked fine. The other was also in the PS and it was a large cap that was just slow to take a charge. Don't know that either of these fit your situation but that is the only two times I have experienced a problem of that nature
Mar 12, 2014 | Sega POWER BASE CONVERTER
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Jan 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
TV shuts off after 15/20 mins!!
 Dear customer,
       It could be the transformer. The problem with protection circuit shut downs is you don't know which section is causing the trouble.  The protection system is really just a current sampler that when it detects an excessive current it opens up the power relay and shuts the power off.  And, as you indicated, unplugging for a few minutes will reset the protection detector.
But, there are about 8 or 10 sections within the tv and you don't know which section has the excessive current.   Most common causes are power supply, high voltage supply, deflection amplifiers or audio amplifier.  It usually takes a tech a few minutes to take some voltages and other checks to zero in on the culprit. Once the section is known then that tech can troubleshoot it for the bad component or shorted condition.
               Usually  it works fine until there is a signal coming in through the coaxial port. that is wen the tv gets switched off. Its a possibilty. Checking the  power supply unit of ur tv and see if it has malfunctioned and  check your power cable for starters..
Plz rate this solution.. thank you..
Apr 08, 2009 | RCA F31672ET TV
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Incorrect power management
Dear u have a problem with VGA or Monitor...U should try to put new vga in you'r mother board and try.If still wont work then you have a problem with monitor
Oct 11, 2007 | ASUS P5LD2-VM Motherboard
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Westinghouse LTV-19W3 19 in. LCD Television Logo
24 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
