Question about HP OfficeJet d145 InkJet Printer
Out off ink
The machine keeps saying out off colour ink even if i try doing a black copy and the ink has been changed
    Genius:
  • 2,985 Answers
When you say the 'ink has been changed do you mean colour or black only. It does not matter what you are trying to print the printer must have a full set to function, If you have a full set remove the cartridge[s]. Switch off the printer wait 30 seconds switch on put the cartridge carrier to its proper position and reload the carts Further info from www.fixyourownprinter.com
Posted on Jul 03, 2007
6ya staff
SOURCE:
I have an Epson XP-202 printer which I use solely as a black and white copier. Accidentally I pressed the colour button for a copy which ( as the original colour cartridges are still in the machine) has...
Not sure about Epson but I had the same problem and the store where I buy my ink said that a lot of the printer companies require all the color cartridges with ink in them to work. My color use to disappear even if I just pushed black and they said that was the way they were made . They sell printers quite cheap but make their money on the ink. I got rid of mine and purchased a black only ink jet and it hardly uses any ink at all. Its a powder. You can copy many copies on eighty dollars worth of ink where the cartridges I went through several hundred dollars a year.
Jun 14, 2017 | Epson Office Equipment & Supplies
We use our fax-1840C machine for black/white only, never for colour. we have installed both b/w and all 3 colour cartridges, but quite soon the fax says the (unused)colour cartridges are empty or dry and...
try by buying a new cartridges like the one you use before and clean first the print head to remove the smodges. see also you manual for compatibilites and instructions. ill find another solutions if this wont help you.
CHARCOIS
Oct 09, 2008 | Brother Office Equipment & Supplies
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Canon MP240 printer LCD alternates between P and 2.
Not sure about your machine but my Cannon would not work when my colour ink was low. The store I bought it says the manufacturer does this to sell coloured ink as well as black. The setting might say for black ink but there is a certain amount of colour goes in as well. I hardly ever used colour as I do business letters so I purchased a black ink jet which uses a black powder and I get 3000 pages for about 75 dollars worth of black jet powder.
Aug 12, 2017 | Canon PIXMA MP240 All-In-One InkJet...
Do you have to have colour ink when only printing in black
Yes you have to have ink in all of them. No, accordign to Canon it wil not work without them.
Feb 04, 2009 | Canon i80 InkJet Printer
My fax machine keeps saying change balck ink even after I did
You need to connect it to your computer and go to the properties.  Select install new cartridge.
Feb 02, 2009 | Lexmark X125 All-In-One InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
PIXMA MP830
Some machines are very expensive to run.
If you are copying in colour mode, even if the page you are copying is just black & white, it will use all four colours to produce the black copy.
Change the mode to black and white and it should save you some money!
Feb 03, 2008 | Office Equipment & Supplies
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP OfficeJet d145 InkJet Printer Logo
71 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
