Question about Motorsports
02 toyota corolla will start but not run.longer than 5seconds
This has been an intermitent fault for 2 years but would come good if left for 4-5 hours. Now its a permanent condition.
    Problem Solver:
  • 7 Answers
Alot of times it can be a simple gas filter situation. The initial burst of fuel might just pass thru the filter. But after that burst it swells back up. As well check your fuel injectors, Fuel lines for gas leakage. Alot of the hoses rot out and gas leaks out. As well fuel pump issues. I attach a fuel gauge off my rails for this reason.
Posted on Aug 22, 2016
  • 3,357 Answers
Sounds like a fuel delivery system problem. trouble shoot all components of the system, starting with the fuel pump.
Posted on Mar 10, 2016
  • 36 Answers
Check the Air Cleaner if it is Petrol, if Diesel it could be the Diesel supply pipe has air in, release one of the diesel pipes turn Engine over see air bubble maybe! try this either can be problem. Malcolm Campbell
Posted on Feb 03, 2016
  • 954 Answers
Check fuel pump pressure, fuel filter for clogged, fuel line if purged, fuel tank valve which is attached to the chassis above the fuel tank.
Posted on Dec 22, 2013
1992 toyota corolla running rich
run fault codes to determine if O2 sensors are at fault. Check MAF/MAP sensors Replace air filter. Have a pressure test done on the fuel manifold to check for excessive injector pressure. Check injectors are working correctly and that the seal at the tips is good
May 21, 2014 | 1992 Toyota Corolla
2007 toyota corolla le check engine light keeps coming on. Sometimes doesn't come on until I reach 60mph
Could be a number of things. Probably a sensor intermittently registering a fault. Take her to the shop and have them run a fault check for any codes. (02 Sensor)?.. IAC Valve etc.
Nov 16, 2013 | 1996 Ford Windstar
Toyota Corolla 2000 intermitent headlights not working
I would check ALL your fuses. you have two area's 1} box under your hood and 2} inside vechile by the drivers side. make use none are burnt
Feb 11, 2013 | 2000 Toyota Corolla
Check engine light came on recently. Car then
The exhaust system has two 02 sensors One before the cat converter and one after. The #2 02 behind the cat converter is the one that trips the light if emmisions are unacceptable coming out of the converter. The #1 or front 02 sensor monitors and constantly adjusts the fuel to stay within parameters. If the #2 tries to compensate for an inefficient converter and it conflicts with the #1 02, the ebgine will run poorly due to either too rich or too lean fuel adjustment. Have the #2 02 sensor replaced and the converter checked. Good luck
Nov 15, 2009 | 2005 Toyota Corolla
The engine works for an average of 2 mits, doesn't rev again
Ask your repair person if they have a car computer fualt code scanner if not find someone who does.It will take about two minutes to check to get a positive fault code and will tell you what is wrong.hope this helps,Regards Stefan.
Jul 08, 2009 | 2006 Toyota Corolla
2003 Toyota Corolla 30 amp keep blowing
it sounds like when the cat was changed they have trapped a wire or just moved one over a bit and its rubbing think about what items this 30amp fuse is protecting are any of the items close to the exhaust or around that area, i dont see the aftermarket starter doing this after 2 years hope this is helpful regards JR
May 17, 2009 | 2003 Toyota Corolla
2000 Toyota Corolla wont start Changed 02 sensor disconnected bat
I had the same problem, i had to remove the whole alarm system to get my car to start, when you unattatch the battery cables, the alarm notices the battery drain and sets the alarm off, i have no idea how much the dealership would charge for a new remote, but im sure its pricey, i would recommend just removing the alarm system, temporarily, until you can get a new remote. Good luck and god bless
Apr 17, 2009 | 1998 Toyota Corolla
1988 corolla Running rough
does it need plus and point and wires
Feb 07, 2009 | 1988 Toyota Corolla 4 Door
Heater (and a/c) blower motor runs only at the two highest speeds
I had the same exact symptom (02 Prizm LSI)..Order yourself a Blower Motor Resistor (I clicked on it---scroll up on this same screen that you are reading--- AC Delco part, $25.79). When the part arrives, look at it, and then look behind and to the left of your glove box door, YOU WILL SEE IT RIGHT AWAY. 2 screws, takes about 10 minutes to change. Its been nice to get all 4 speeds back! Good luck.
Dec 05, 2008 | 2002 Chevrolet Prizm
Motorsports Logo
446 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
