Question about John Deere Garden
John deere x300 mower pto wont ingage even engine run
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 246 Answers
SOURCE: I have a John Deere Riding lawn mower which starts
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
How to remove and replace pto clutch on John Deere x300 mower
Unplug the wires to the clutch, the wires plug in on the right side. Remove the bolt retaining the clutch, 5/8 socket. You might need to take 2 pry bars, one on each side of the clutch on the top side to work it loose.
Jul 30, 2017 | John Deere Garden
John deere d140 lawn mower shoots of when i ingage the blades
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE D140 SERVICE REPAIR MANUAL
May 04, 2017 | John Deere Garden
Where is the fuse that runs from the p.t.o of a John Deer riding mower ?
Go to upstateoutdoorpowerequipment.com, look up your engine type not mower brand and you can get an illustrated parts view of it. If not in engine type parts view you can look it up in your mower brand. Engine will have a plate on it that gives engine info. Mower info is usually under the seat. If PTO is not engaging it usually means low battery charge or the PTO switch is bad.
Oct 24, 2016 | John Deere Garden
John Deere x300 series 2009 model I unhooked the kill wire and it started. But now my mower/pto will not engage is there a way to bypass the sensor?
Based on the combination problems involving the coil kill wire and the PTO activation, I would suspect the PTO switch is bad.
I do not have a schematic for the 300x, however I most of the functions are comparable to the LA 145, 165, 175.
The PTO switch is a multifunction switch. It will have 3 to 4 different functions internally. On the LA 175 it serves 3 functions. These 3 internal functions are independent of one another. Electronically they are known as single pole/single throw switches. In other words even though they are all housed inside a single unit they act light 3 separate light switches in your house.
One function ("light switch") controls your cranking system. When the key is turned to Start, power flows from the Key switch (purple wire) to the PTO switch. With the PTO switch off it flow out (purple/white) and goes to the Brake switch. If the Brake is set the power flows through to the starter solenoid and your engine cranks.
Another "light switch" inside the PTO switch controls the Blade Clutch. Power flows from the Key switch, in run position, (yellow wire) to the PTO switch. With the PTO switch on it flows out another yellow wire to the Blade Clutch. A DC volt meter should show 12 volts switching on and off as the PTO is turned on and off.
The third "light switch" completes a Ground Path. This ground path is a totally separate pathway running through the PTO switch. The ground system is fairly complex because it operates differently under different scenarios.
To produce a spark, the key switch must be in the start or run position. While starting the PTO must be off and the brake set. The seat switch does not matter at this point.
Once the engine is running the seat switch plays a part if the PTO is activated or the Brake is released. Someone must be in the seat.
The Kill system is activated
  1. When the key switch is turned off.
  2. When the operator leaves the seat without setting the brake and turning off the PTO.
  3. When the machine is reversed while the PTO is engaged and the back up switch (RIS) is not pressed.
So there are three different paths to ground; any of which can kill the engine by grounding the coil. Except for turning off the key, all other grounding functions flow through the "grounding light switch" in the PTO.
Because you have a combination problem, the Coil kill wire is grounding the engine and the Blade Clutch won't activate the blades; both of which are affected by the PTO switch, odds are you have a bad PTO.
Obviously there are too many complex functions to just bypass the switch. You will have to replace it. The part number you need is AM135131. You can do a site search to locate and order this replacement switch for about $26.00 including shipping at this site: GreenPartStore Parts for John Deere Lawn Tractors John Deere Lawn Garden...
Mar 29, 2015 | John Deere Garden
Ive got a john deere 4055. Has a new clutch and pto release bearings and piston. The pto will not ingage and there is no pto pressure.
did the mechanic that installed the new parts pre prime the hydraulic pump on install , ive had limited luck using another tractors pump on remote circuit to back feed on the return line to "externally) prime the pump , but it has worked a few times , worth a try if you have the means
Mar 28, 2015 | John Deere Garden
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
John Deere 314 garden tractor PTO mower deck kills engine
bypass the safety switch on the seat to test that one
Aug 13, 2012 | Garden
John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Engine starts and runs Great. When I engage the Pto leaver on my John Deere L100 the mower fails.
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Jun 07, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
417 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
