Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
I have a 6 year old F&P GWL10 washing machine that is stuck in the rinse cycle. It recirculates water into the tub and will not drain. First the machine would not come on. A serviceman replaced the pump. Then the machine would power up. We started the wash cycle and it got to the rinse cycle and would not drain. So, the serviceman replaced the diverter valve. It still would not drain. It just recirculuates the water into the tub. The amount of water in the tub does not get higher or lower. The water just keeps coming in the tub, but won't drain. If you turn the power off and try to start over it starts in the middle or the wash cycle and starts to fill the machine with more water. Then we have to manually scoop the water out. We have invested over $200 so far in trying to get it to work. Because we live in a rural area in Indiana service calls are very
expensive. Do you have any suggestions as to what might be the problem? We are trying to decide whether to continue to spend more $$ trying to get it to work or just throw it over the hill and buy a new washing machine (not Fisher & Paykel, though!) Thank you!!!
  • janet466 Feb 01, 2009
    I have a washer model GWL08 and am experiencing the same problem. It got as far as the rinse cycle and then stopped. I emptied out some clothes thinking I might have overloaded it and also changed the water level from auto to medium. It won't drain so I emptied out the clothes and water manually and took out the agitator to see if anything was stuck. There was nothing stuck so I turned off the machine and found this forum.
  • houser_d Feb 01, 2009
    My fisher & paykel model GWL 11 won't finish the rinse cycle. The first time the water drained out but wouldn't complete the rinse cycle. I took out all the clothes and put in a couple of items and started the machine again. This time when it reached the rinse cycle it stopped with water in the tub.
    I purchased this brand thinking it was suppose to be a much better machine. Having trouble within 3 years is not what I was hoping for.
  • 3 Answers
No power from the control board to the diverter.replace control board.it is about $150.00 for the part
Posted on Jan 25, 2009
Smart drive 601
If it is out of balance it will automatically return to a wash cycle to try and redistribute the clothes more evenly. Maybe the out of balance switch is faulty. More likely though is a faulty control board. If that then get a new washing machine. That model is over 20 years old. Not worth spending money on it.
Jan 23, 2018 | Fisher and Paykel Fisher & Paykel Washer
Fisher paykel GWL10 doesn't drain Previous problem
Easy to check the pump but you need to have a bucket handy. Tilt washer backward pump will be on the right side. Remove and clean. Watch out for the water!
Sep 26, 2013 | Washing Machines
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
I have a 10 year old Fisher & Paykel GWL10 washing machine. Fault code 1 is coming up. The machine turns completely off. The longer it cools down, the longer it goes before turning off again. This...
Code 1 - usually means on the later models of Fisher & Paykel is a faulty Motor Control Module, often though one would have to replace both as well as the display module.
Anyway - it sounds like the electronics are overheating hence the intermittent problems you are experiencing.
May 27, 2011 | Fisher Paykel EcoSmart GWL15
F&P washing machine will not rinse, drain or spin, pump seems to be ok because water recirculates during rinse cycle. I shorted lid switch. Still, same problem.
Hi just read your posting.Now to help you I need the model number of your machine which is located on a sticker at the back of the machine top left.Sounds like you have a diverter problem.The machine will recirculate the water but the diverter wont switch over for the machine to drain the water.Could be a stuck diverter or a faulty control module.Please reply with model number and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 19, 2010 | Fisher and Paykel Washing Machines
Wont adavace after wash cycle like its stuck
Hi just read your posting.Now just a couple of questions.Does the machine empty the water if you advance the cycle to spin?Did it show a series of lights when it was beeping which indicates the fault code?My guess on what is wrong with your machine on the information that you posted is the diverter valve which is inside your pump is stuck on the recirculating position , causing the machine not to drain the water .Please reply back and if you can remember, tell me the error code .Also reply back and I tell me if it is draining on a manual spin.
Jun 06, 2010 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
889 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
