Question about Dell 5110cn Laser Printer
Dell 5110cn says restart printer, contact support. when i unplug it and plug it in again it does nothing. i have tried to take toners out, put them back in etc no button i push changes anything,help.
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Posted on Jul 17, 2008
Corysf62
  • 188 Answers
SOURCE: Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
Posted on Sep 28, 2008
Bappa170873
  • 505 Answers
SOURCE: Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Thanks
Posted on Nov 07, 2008
SOURCE: flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
Posted on May 29, 2009
SOURCE: what is the hard reset for Dell 5110cn
I have a dell 5110 cn laser printer and the transfer roller just went out.. How can I re-set this since I do not have a replacement roller. but i need ot order. Thanks
Posted on Jun 22, 2010
Dell 5110cn, says change magenta toner, crum 093-961. canged toner. still has same display
Your Toner Dispenser TF123 could be bad. It is probably not reading the chip on the Toner.
Or possibly you are using the wrong toner. Dell 5100 or Xerox 6300 looks similar and might fit. Also, if you are using 3rd party toner, check that they have caused your problem.
Whit
Item, Inc.
Aug 24, 2010 | Dell 5110cn Laser Printer
003-345
Please reply with exact error so that we can find solution....................thanks.
Jul 02, 2008 | Dell 5110cn Laser Printer
My Dell printer 5110CN will not print black, changed toner cartridge, and fuser,
There are design flaws in the "powder feeder" that sits bellow the black toner. There is no way to repair. There is a spring that burst after uniforms 250 000 prints.
Mar 03, 2010 | Dell 5110cn Laser Printer
DELL 5110CN PRINTS PRINTS LIGHT GRAY NOT BLACK!
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Dec 27, 2009 | Dell 5110cn Laser Printer
After replacing fuser, I get "10-397 Restart Printer" I've tried six new fusers in five different printers and get the same error on every one. I've tried leaving the printer unplugged overnight and it did...
Have you checked that there is enough toner in the cartridges. It may help to remove the cartridge, shake the toner quite rigourously, replace, restart the printer. Also make sure that the paper is not cold or damp.
Oct 20, 2009 | Dell 5110cn Laser Printer
DELL 5110CN 093-426? What error is this?
093-426 is a "black toner replace soon" error message. first make sure that you're using a dell-branded toner cartridge (you can order online here: www.dell.com/supplies) & you can try reseating the black toner cartridge.
Jul 13, 2009 | Dell 5110cn Laser Printer
Color
5110cn is printing in pink. Toner cartridges are not out.
Aug 26, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Problems
Have you replaced the fuser?
Have you replaced the toner?
Have you order a PM KIT? Most of these kits also comes with the fuser , transfer roller. or imager?
These items above should be replaced.
Jul 28, 2008 | Dell 5110cn Laser Printer
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-693
crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
Mar 16, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
