Question about Exercise & Fitness
York T302 treadmill stops after 30 secs
Unit operates only for 30 secs with a "heavy footed" runner, but operates OK for hours with a light footed action. Seems perhaps to be some confusion for the control board in matching motor speed with belt pulses from magnetic sensor. Red light falshes strongly when the "heavy footed" person is jogging, and at the frequency of impact with the mat - but lights up only intermitently when the light footer person jogs. A quite seperate problem is the main house earth leakage relay drops out unless the control board earth is removed. Mag reed switch seems to be closing OK and is close as it can be to the magnetic trigger on the mat drive pulley. Are these control boards repairable or is it all surface mount stuff that cannot be component replaced. Craig B
    New Friend:
  • 25 Answers
you can countinue contact us with smart phone on wattsapp or telegram by :
Posted on Apr 10, 2017
5 Suggested Answers
SOURCE: Proform 730i powers on but will not move when I input speed.
I have the same treadmill with the same problem statement. Here is how I fixed it:....Open the lower shroud that covers the motor. You must remove 4 or 5 screws. Taped to the inside of the shroud should be a document with a calibration procedure on one side and electrical specifications on the other. It will tell you how to run the calibrations. You need to hold the stop button and the + speed button as you insert the safety key. This will put you into calibration mode. My treadmill started working again after I ran the incline calibration routine. Hope this helps.
Posted on Oct 31, 2009
  • 83 Answers
SOURCE: No motor output to drive the belt
Sounds like that there is a short in the control board.
Posted on Mar 24, 2010
  • 832 Answers
If speed ctrl LED is flickering and no DC output on motor spade then the motor control board is defective and needs to be replaced
Posted on May 18, 2010
  • 43501 Answers
SOURCE: On my treadmill walking everything
The belt is slipping a bit... try tightening the belt a bit and you will be fine...
Posted on Jul 12, 2011
My York fitness aspire treadmill stopped working and now it will not come on
If you wish to get some details; check the site linked here. Pull up older posts. Refer treadmill articles.
May 17, 2016 | Exercise & Fitness
How do i change running belt for york paacer 4600 treadmill
Remove the motor hood cover, side foot rails, front and rear rollers,and walking deck. Takes about 2 hours to do
Mar 04, 2015 | York Exercise & Fitness
York Runner 61820 won't run
the motor is faulty. That is why its warming up fast than usual. Motor is consuming more current thats why the relay cuts the power. change the motor.
Feb 21, 2014 | Exercise & Fitness
Proform tredmill starts runs 10 sec and beeps twice and stops
I would suggest unplugging the unit from the wall and waiting 30 second and plugging it back in. Then go to where the AC cord enters the machine and look for a reset button or switch. Put it in the reset position and see if this solves the problem. Depending on model the reset may be on the bottom of console.
Dec 15, 2013 | Proform 520 Trainer Folding Treadmill...
T302 treadmill
see the videos and fix it. GOD BLESS YOU
Jul 21, 2013 | Exercise & Fitness
Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
My York t302 threadmill motor starts to keep strange noise after some running. Motor has been changed once as well as whole threadmill. So this is my third motor and problem still exist. Here is the...
i just had a noise in my York T301 that sounds exactly the same as yours. It also came up with a E1 error code and stopped working. I pulled the motor hood off and noticed that the magnet in the drive pully had come dislodged. It was hitting the speed sensor near the belt. Glued magnet back in and all better. Hope this helps.
Oct 06, 2010 | York Barbell Home Use Fold-Up Treadmill
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
Where is the circuit breaker or fuse message err 1
That error code mean you motor is not getting the correct signal to operate the drive motor. You will need unplug unit then take the motor shroud off visually inspect all connectors then make sure all of them are seating solid in their connectors. then plug the unit in check an see if the L E Ds have lit on lower electronics board then get on unit and with your foot proceed to move the belt while doing that hit your start button and see if that error code come up. At this point we are checking the speed sensor to see if it is functional. Now if your upper console is registering its showing speed and time moving forward this also tells us that the communication between the two boards are fine. Now stop this process and you should have the error 1 show on the console. If you have a multi meter handy find the two leads coming form the motor going to the board unplug them put the two leads into the connector switch the meter to dcv 100v range and proceed to move the belt in the previous now the motor has become a generator and if function you should be getting a dcv output if not the it telling either worn motor brushes or open winding in the motor now if you get a reading then that lower board is defective. Then call York and get pricing on the defective part.
Apr 11, 2010 | York Barbell Home Use Fold-Up Treadmill
It has stopped and smells like a motor is burning comes up with error 1 Its a york Barbell treadmill and is model number T-406 LA
Ok! how I say, just send your motor DC to repair, at the same time, check the engine controller. any diode or mosfet is bad or damage
Feb 04, 2010 | York Barbell Home Use Fold-Up Treadmill
Exercise & Fitness Logo
78 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
