Question about Echo Backpack Blower PB-770T
How do i remove the fan from echo backpack blower
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: ho spark on a pb 403t backpack blower
Well obviously you need to check the spark plug for fire. Try the old one first, then a new one. If you still don't have fire, then you probably burnt out the coil.
Jim
Posted on Nov 30, 2009
  • 150 Answers
SOURCE: I have the Echo 413H
Sounds like a carbuerator adjustment. Turn the low speed adjustment screw counterclockwise 1 guarter turn.(closest to engine block) Turn the high speed out the same (farthest from engine block). You may have to tweak it a little, those adjustments vary. Hope that gets ya going.
Posted on Dec 21, 2010
Echo leaf blower pb-261l part#10491011410 the part broke between the backpack and blower got the part off the backpack one is still in blower how to get that out
Take apart the blower and then re-assemble it according to the manual then you should be able to find and fix the problem.
May 18, 2017 | Echo Garden
Echo backpack blower bkue smoke
Sounds like mixture is too rich. Get correct mixture per manual and refuel.
Jul 11, 2014 | Echo Pb - 413t Backpack Blower
Where is the fuel air mixture screw on a shindaiwa backpack blower
Look on the side of the carb. they are there. You will probably need to remove the air cleaner form the carb to see them and then you may need a special tool to adjust them due to the EPA covers on the screws. Hope this helps.
Jun 27, 2014 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Echo 770t misfiring
I have installed new carb kit, fuel lines, plug, and air filter. Blower continues to bogg down when opening up throttle. echo 770 blower any ideas?
Aug 13, 2013 | Echo Backpack Blower PB-770T
Echo blower wont start
ignition coil fixed my still backpack last fall
Apr 02, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
Cord is locked, or maybe its the motor. Its an Echo PB260L Backpack
This is easy enough to check. There are 4 screws that secure the recoil starter to the engine. Remove these 4 screws and remove the starter assembly. Pull on the rope and see if the starter is operating properly. If not, go to your local Echo dealer and get a new one...they are about $30. Also try to turn the starter cup by hand to see if the engine is locked up. If the engine is locked up, remove the spark plug and try to turn the starter cup again. If it is still locked up, then the repairs would cost more than a new blower.
Dec 20, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Need to replace fuel filter
Fuel filter is located inside the fuel tank. You have to make a hook out of about 10" of stiff wire (wire coat hanger works perfect) Hook end should be about 1/2" wide. Remove the fuel cap, insert the wire hook and snag the fuel supply tube with the filter attached to the end. Pull it back through the fuel filler opening, replace the filter and reinsert.
Apr 14, 2009 | Echo Pb - 413t Backpack Blower
Echo Backpack Blower PB-770T Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
