Question about HP 50g Graphic Calculator
I bought my HP 50G 2 years ago but left it in the box. Took it out today, turned it on and got a Warning: LowBat (S). I put in 4 new AAA batteries. Got same message. The manual said that that woul
Of course my warranty is up, so I won't get any help from HP. Any suggestions. But when I click on various keys, I get a beep. I also see what looks like a little triangle blinking above the header. Also what is strange is that I am not in Home, but in Home Pythag. The SR2032 battery is supposed to last for years. I am afraid this is a total lemon.
SOURCE: HP 49g+ Calculator Does Not Turn On
Try n cold start, reseting the calculator, introducing an wire in the back small oriffice in the calculator. It may fix the problem.
JC
Posted on Nov 05, 2007
  • 3278 Answers
SOURCE: HP laptop does not start.LED on.black screen "warning-battery low
Remove the battery and try to power on with A/C. If the laptop works, the battery is faulty. If the laptop does not work, could be an AC adapter problem.
Posted on Jun 12, 2009
  • 7993 Answers
SOURCE: TI-83 Plus calculators won't turn on despite the many attemps...
It is possible that the contrast is too light as to make the cursor invisible.
In that case you can increase the contrast as follows:
1. Press [2nd] key , then release it.
2 Press [up arrow] key ,then release it.
Repeat the two steps until you get the right contrast.
To decrease the contrast, you press the [down arrow] key instead of the [up arrow] key.
Hope it clears the obscurity.
Hope that
Posted on Aug 26, 2009
SOURCE: the calculator, hp49g+, will not turn on by pressing the "ON".
Hi, if pressing on and F5 together immediately starts the selftest your keyboard is OK, but one of the capacitors on the HP49G PCB are broken. I replaced all three and the turn on/off problem was gone.
Hope this helps.
Joachim
Posted on Nov 20, 2009
  • 7993 Answers
SOURCE: My HP 48G does not come on.
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the begining of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
You can also try this site. They do repairs on most models, except the newer ones.
Hope it helps and Thank you for using FixYa.
Do not forget to rate the solution.
Posted on Nov 30, 2009
Total and sudden power failure
Saw this once before..Could not believe it but it was the battery. Crazy thing happen when the battery is low.
Jun 02, 2017 | 1999 BMW Z3
HP 50G wont turn on. The thing is only 2 years old. The batteries went and so I replaced them and no response. Even with the reset, I dont get anything
Well, it's either a new set of batteries or simply reinserting them to establish better contact. Another thing to watch out for: after a time the metal contacts can get bent out of shape so they no longer press against the batteries hard enough for reliable contact. The fix for this is to fold up a small piece of paper and jam it under the contact to add a little thickness.
Anyway, glad to hear you're back up and running.
Mar 26, 2012 | HP 50g Graphic Calculator
All of the sudden it stopt working. Nothing happens when I push the ON button. I changed batteries. I took the backup battery out and put it back in (didn't put new one). Nothing helps. I changed the...
It is sold with an dapator that powers the calculator through the USB port. Use it and you will eliminate any doubt about the batteries. Try resetting the calculator.
Aug 26, 2011 | HP 50g Graphic Calculator
Going through alternators
Hi there, I am a girl (i.e. not car savvy), but I have a 1998 Altima as well, and the first time (4 months ago) I noticed the brake and battery lights on simultaneously, I took it to a Nissan service shop. Everything seemed fine until about a month ago when the symptoms returned. I ignored the problem for 3 days and the car just stopped running, period. Took it back to the shop, figured out it was a fauly alternator, got it sorted, no problem. Today (1 month after replacement), I see the same bloody problem, and I'm taking it back to the shop in the morning. I am wondering... is it the alternator, or something connected to the alternator that is malfunctioning? The 2 alternators put in were "rebuilt" since they didn't have genuine Nissan alternators available. I really hope the dealers aren't taking me for a merry ride.
Jul 13, 2010 | 1999 Nissan Altima
Hyundai Atos GLS 4 door hatchback won't start/turn
If you have not found the problem yet, check the transmission interlock. Sounds like the shifter interlock switch may not be engaging to allow the starter to activate!
Nov 09, 2009 | 2001 Hyundai Accent
I turn on the calculator and it comes up with the little black thing in the left hand corner. Then it turns off. It doesn't allow you to do anything, it just shuts off. At first I thought there was a...
Your calculator may need to be reset. Open the battery door. There's an internal battery behind a little door with a screw right above the 4 AAA batteries. Take this battery out. Leave it out for about 8 hours then put it and the AAA batteries back in. Hopefully this will solve your problem.
Jul 10, 2009 | Texas Instruments TI-84 Plus Calculator
My hp jornada 728 wont charge or turn on
2000 year of introduced series. 728(2002) sold only in the UK.
is not new product by far. (in dog years it's. 100 years old)
IMO it belongs in a Museum.
hihi
put a new battery in it? (hope1)
this thing is old.
does it run with the battery out?
if not then the A.C adapator is bad (hope)
hope means , not bad INSIDE.
May 09, 2017 | HP Jornada 728
The calculator casio CFX 9850GA was not turning on..
first:you must clean battery compatrment in direction of contact point with good contact cleaner from any electronic store near you or from radio shack.
second:clean power switch with contact cleaner.
Dec 21, 2007 | Casio CFX 9850GA Plus Calculator
HP 50g Graphic Calculator Logo
15 people viewed this question
Seeker5211
Seeker5211
