Question about Keurig Special Edition B60 Coffee Maker
My coffee maker is making an unusual "squeegee" sound when heating the water.
It is making an unusual sound that it wasn't making before. I know it makes a gurgling and burping type noise to heat the water, but the last couple days it has changed to a slow squeegee sound. The best way I can describe it is like on Willy Wonka when they get sprayed with whipping cream and go through the cleaner. HELP! Do I take it back for a new one or can it be fixed? I've only had it a couple weeks.
    Master:
  • 253 Answers
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Posted on Nov 25, 2013
BarrettDenCo
  • 1772 Answers
SOURCE: keurig coffee maker makes loud noise single cup
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 21, 2010
SOURCE: Coffee maker makes cream curdle
Run two or three reservoirs full of plain water through the machine to rinse out the descaler, which is acidic.
Acid curdles milk.
Posted on Nov 21, 2008
danforddan1
  • 192 Answers
SOURCE: COFFEE MAKER IS MAKING LOUD NOISE AND WON'T BREW COFFEE.
Do you have hard water or othe deposits in the water.? It may have just limed up. Try soaking it for a couple of days with Vinigar and water . put a healthy amount right in there add sum H20 and waite. this may free it up Good luck. DSFD
Posted on Apr 13, 2009
  • 7 Answers
SOURCE: mini brewer shuts off wont heat up wont make
thow it on the ground and stom on it. if its not working now theres nothing you can do. Take it to the dump
Posted on Jun 28, 2009
SOURCE: i just plugged the coffee maker back its not making coffee!
So folks to solve this problem I used the last resort....don't laugh, but I actually started to hit the machine very hard on the top and from the side and all of sudden it started to work. When in doubt hit it!
Posted on Oct 19, 2009
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
I have a one cup at a time Keurig. I measure the water and pour in then Kcup coffee. I shut the covers and press brew. The coffee maker starts to heat the water but then will not pump the water through...
I have one too. Had the same problem and needed a new clean Kcup. The oil residue build up wasn't allowing the coffee to pass through. Some models also have internal filters. Bed Bath Beyond has all the replacement parts and lists the units by Model on the part. Hope this helps.
Sep 05, 2011 | Vacuums
Prime message and blue blinking light. It has plenty of water, I don't understand why it isn't working. Please help, Jenna
what exactly is it doing? need more information than prime message and blinking light.? please give me more info. lkadera@gmail.com.
Aug 29, 2011 | Keurig Platinum B70 Coffee Maker
Coffee maker water does not heat
unless you have a real expensive coffee maker, it is cheaper to just replace it at this point. chances are the heating element has burned in two.
Jun 20, 2009 | Braun Coffee Makers & Espresso Machines
Heating element issue?
Hi sounds like a thermastat problem control needs professional tech to look at it cheers john
Jan 18, 2008 | Saeco Magic De Luxe Espresso Machine
Keurig Special Edition B60 Coffee Maker Logo
272 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
