Crosley heavy duty giant capacity plus washer model # cw6000w.
Need to no what size tub it has
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Posted on Jul 23, 2009
  • 6277 Answers
SOURCE: I have a Kenmore 80 series, Model 110 26862501;
I would think that sort of information would be on the manufacturer's plate, probably at the back, and/or in the manual.
If you have no manual you will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jul 07, 2011
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Where is the heating element on a crosley heavy duty giant capacity plus
The element will be at the back of the dryer behind the drum I will give you a link to a video that will show you how to do this .It is not a hard fix and takes 15 to 20 minutes..
Jul 04, 2012 | Crosley Dryers
I have a Kenmore 80 series, Model 110 26862501; Serial #CS3203368 Washer Heavy Duty Super Capacity Plus. I need to know the cubic inch size of the tub.
John C.
Jul 07, 2011 | Kenmore Washing Machines
We took our heating element out of our dryer and didn't mark the wires. Is there somewhere I can download a map of where the wires go? It's a Crosley heavy duty giant capacity.
How many wires do you have? If only two, the heater element doesn't care which wire is attached since it is being fed with AC current there is no polarity to it.
Oct 29, 2009 | Crosley CDE6000 Electric Dryer
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Crosley heavy duty giant capacity plus auto dry control wont dry
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2009 | Crosley CDE6000 Electric Dryer
Washing Machines Logo
261 people viewed this question
Top Washing Machines Experts
