Question about Palmer "prodigy" Snowboard Mens 160cm
Length of board
Hi there
I am 5'9" in height and 13 stone in weight. What length of board should I be looking at.
Also I have been looking at a Palmer Prodigy board. It's my third week boarding and am reasonably competent on a board and I like boarding on piste and off piste. Do you think that this board would be suitable?
Many thanks
James
    Problem Solver:
  • 8 Answers
It's more about personal preference. I'm 5'8" and weigh 155. I ride a 155 burton blunt and 147 ride kink. For days with powder I like the longer board and for packed powder days and park days I love the 147. There's no one size that's right or wrong. If you like doing tricks a smaller board may make it easier if you like crusing a longer board makes sense. The longer the board the faster you'll go. The Palmer Prodigy is a fine board, a 160 would be well within the range you can ride, remember you're only talking a few centimeters difference between many models. Good luck and stick with it!!
Posted on Feb 10, 2009
Honda crv dimensions
HondaCRV is an best Suv car across the world as it the style, good mileage and best in class interior features to beat competition in the auto industry.Here I have mentioned the dimension of Honda CRV 2WD, take a look
1) Length:
4545 mm
2)Width
1820 mm
3)Height
1685 mm
4)Wheelbase
2620 mm
5)Front Track
1565 mm
6)Rear Track
1565 mm
7)Ground Clearance
170 mm
8)Kerb Weight
1475 kg
9)Gross Vehicle Weight
1830 kg
10)Boot Space
490 litres
11)Fuel Tank Capacity
58 litres
12)Minimum Turning Radius
5.5 meter
Check out the Test Drive video of Honda CRV.
Oct 11, 2017 | Honda Cars & Trucks
What are the specs on a 2006 suzuki blvd 800?
Try here:
http://www.globalsuzuki.com/motorcycle/moto/cruiser/vz800/spec.html
Overall Length U.S. & Canada specs. : 2,395mm (94.3 in.)
Other specs. : 2,420mm (95.3 in.) Overall Width 890mm (35.0 in.) Overall Height 1,105mm (43.5 in.) Wheelbase 1,655mm (65.2 in.) Seat Height 700mm (27.6 in.) Curb Mass 269kg (593 lbs.)
Nov 17, 2014 | Suzuki Boulevard Motorcycles
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
What are the dimensions of t his dutch oven?
According to Amazon, the dimensions are as follows: 15 inches in length, by 13 inches in width, by 9 inches in height/depth. It also weights 13.8 pounds.
Feb 16, 2014 | Tramontina Gourmet Dutch Ovens: Enameled...
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
Battery size group?Avalon 04, 3.0
Group Size: 35
Voltage: 12
Cold Cranking Amps (CCA) @ 0°F: 720
Cranking Amps @ 32°F: 910
Reserve Capacity (minutes): 90
Terminal Type: SAE top post
Height (in.): 9-5/16
Width (in.): 6-13/16
Length (in.): 7-5/8
Weight (lbs.): 32
Hope this helps
Oct 15, 2010 | 2004 Toyota Avalon
Snowboard length calculation
"Your height (inches) x 2.54 x 0.88 = Suggested Board Length Rider Height Range of Board Length 4 Feet 109cm 4'2"" 114 -120cm 4'4"" 115 - 125cm 4.6"" 118 - 135cm 4.8"" 120 - 135cm 4'10"" 125 - 140cm 5 Feet 130 - 142cm 5'2"" 135 - 145cm 5'4"" 140 - 148cm 5.6"" 145 -152cm 5'8"" 147 -155cm 5'10"" 154- 163cm 6'0"" 157-165cm 6'1"" 160-168cm 6'2""+ 159cm or greater"
Dec 01, 2008 | All Star Forum Star Women's Snowboard
Snowboard length fit
"Length is one of the most important characteristics of a Snowboard. The length of a Snowboard is measured from the tip of the nose to the end of the tail. The length is usually measured in centimeters and often abbreviated to just the last two digits. Board length varies from 100cm to 180cm. To find the appropriate length for you, start by comparing the board length to your height. Although there are no dead set Rules in Selecting Board Length, the following are several guidelines to get you started. When holding the board on its end: * Short board should reach somewhere between your collar bones and chin. Shorter boards are easier to maneuver, great to be trained on, and often preferred by riders who do a lot of Snowboarding Tricks, park and Pipe Riding. * Medium length should come up between your chin and eyebrows. This length is preferred by all around intermediate to advanced riders who ride a variety of terrain, including parks and steeps. * Long boards should go from your forehead to several inches over the top of your head. Long boards are used for high-speed carving, deep powder snow surface, and big mountain terrain. Choosing the suitable board length is not only influenced by your height but also by your weight. Keep in mind that a Snowboard acts like a leaf spring - it has no clue how tall the person standing on it is. However, it does know your weight. Based on your weight or body structure, the following will help you choose the Right Length of Snowboard: * Lighter people should have shorter, more flexible boards. This is because a lighter person on a longer board commonly has a hard time controlling the board and initiating turns. * For an averagely built person, the board length should reach somewhere between the chin and your nose. * Heavier people should have longer, less flexible boards. A short board isn't advisable for heavy riders because the board often have a tendency to ""wash out"" or perform poorly, especially at higher speeds. * Freestyle riding is often done with a shorter board to allow better maneuverability. * Freeriding, deep snow, and racing boards will be longer in size. * For riders who are into Backcountry Snowboarding, go longer for stability. You may also consider your aggressive or timid style. If you're the type of boarder who really attacks the hill, you'll want to increase the length of your Snowboard up to five centimeters from the average size. Then again, if your riding style is naturally slower in character, go down five centimeters. Still, keep in mind that one Snowboard doesn't do it all."
I need the following info for my 1999 Audi S3 in relation to the tailgate dimensions: Height.......cm; Length........cm; width.........cm; wight.........kg
Exterior Dimensions
Wheelbase
2519 mm
Front Track
1527 mm
Rear Track
1503 mm
Overall length
4159 mm
Overall Width
1763 mm
Height (unloaded)
1415 mm
Ground clearance
n
Unladen weight in kg / gross weight limit in kg
1375 kg / 1935 kg
Nov 05, 2008 | 2005 Audi A3
Weight and Length Limitations??
Thanks very much for the info!! Problem solved! I ende up going to Sears and I read the manual that came with my car seat. The weight is from 5-22 lbs and the height is 27"-29" long. Thanks again for all your help.
Aug 20, 2007 | Eddie Bauer Lightweight Travel System...
Palmer "prodigy" Snowboard Mens 160cm Logo
139 people viewed this question
Top Palmer Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you a Palmer Winter Sport Expert? Answer questions, earn points and help others
